help mounting winch with stock bumper
  • 10 Replies
  • 4181 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: October 09, 2005, 07:49:58 PM »
I dont want to cut the grill or the bumper over, but I have a new 4000# winch I want to install.    Anyone else ever done this, or have suggestions, as I'm getting nowhere fast
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: help mounting winch with stock bumper
« Reply #1 on: October 09, 2005, 08:38:52 PM »
Unless you have one of the bumper covers from a 4 door kick with the huge rectangular hole in it, you're going to have to cut a hole somewhere for the fairlead at least. I would look into fabbing a 2" receiver hitch that comes out just under the stock metal bumper through a small hole in the cover. Then you could mount the winch to a plate that slides into the hitch when you need it, and stores behind the back seat when you don't. If you run an extra set of wires to the back and make a rear hitch, you could pull from the back if you need to...
Also, make sure to tie into the frame, not just the stock bumper as it's only held on by 4 10mm bolts. If you pull on the bumper by itself, it will rip right off the front of the truck pretty easily...
« Last Edit: October 09, 2005, 08:40:40 PM by Digger »
Offline Fat Jake
  • 29
  • Broke ass fool.
« Reply #2 on: October 09, 2005, 11:16:08 PM »
I have seen this happen.
The owner didn't care so we all got a good laugh out of it luckily.
5spd 90 Kick 4x4 aka Zuk Nukem
mudfkr
« Reply #3 on: October 09, 2005, 11:48:58 PM »
Stop exaggerating Digger they are actually only 8mm !!! :o
 ;D
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
« Reply #4 on: October 10, 2005, 05:34:42 AM »
Well the bolt heads are 10mm  ;D
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: October 10, 2005, 07:28:43 AM »
mine are 3/8 bolts, put them in myself, non the less, I dont want to mount it to the bumper.  I'm thinking of a tri-pod (quad-pod) style setup,, from the front suspension to the middle just above the bumper, then from just in back of the bumper build a little something that would clear the bumper and then mount a plate on.   where b is the bumper, I is behind the bumper and in front of the rad and 0 is the round bar holding the front control arm assy.  / or \ is in front of the bumper.   thereis enough room on the passenger side to reinforce it towards the frame about another foot back towards the frame
____                  ____
\  B  I                / b I
  \    =         W_/  b I
   \                   \  b I
     0                  \ bI
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« Reply #6 on: October 10, 2005, 10:01:02 AM »
yeah... what digger said... lol.... dont know to much about this to be honest.... but what he said seemed to make sense... ;D
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #7 on: October 10, 2005, 10:09:46 AM »
chile kick has his mounted to a plate that mounts to the frame behind the bumper
ask him for pics
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
mudfkr
« Reply #8 on: October 10, 2005, 11:57:58 AM »
No your wrong....
6mm bolt has 10mm head.
8mm bolt has a 12mm head (which is the bumper ones)
10mm has a 14mm head.
12mm has a 17mm head.
mudfkr
« Reply #9 on: October 10, 2005, 12:04:58 PM »
Here's what I did when making my winch bumper you could do the same and use it to make just a winch frame from it.
I cut the 10mm (3/8") plate to shape with a 4" grinder then taped some 10mm holes in it and welded it in. My bumper ties to both the factory bolts and these one's two as well.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #10 on: October 10, 2005, 01:45:32 PM »
looks alright, I was thinking about something just like it
