SAS
  • 2610 Views
Offline ocb
SAS
« on: October 09, 2005, 08:00:03 PM »
Is there somebody on here named Eric Bewley?  I heard that he did a SAS on a Grand Vitara.  I would like to start collection parts in the Fall and Winter and do the same to mine (1999 GV)in the Spring.   I have a friend that works at ICBC (Insurance Corporation British Columbia) in Canada.  My friend has access to the database of donar cars in all the wreckers in BC so I would have no problem finding parts.  I am particularily interested in what axel he used and what steering box because I heard that neither the IFS Toyota or sidekick would work because the frame is up higher.  Any helpful info would be greatly appreciated.
Offline sergi
  • 307
Re: SAS
« Reply #1 on: October 10, 2005, 02:08:11 AM »
Hi,
Eric would be the forum administrator. As far as I know he doesn't have a GV, let alone a SAS. There was someone on this forum by the name of Snoopy (or similar) with a SASed GV. I think he used a Dana 30 up front. Hope this get's you started ;)
Let us know what you find out!
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
  • 6603
  • 69
Re: SAS
« Reply #2 on: October 10, 2005, 07:14:49 AM »
Hello OCB,
I have a SAS Sidekick and a 'regular GV' (new project vehicle!) there was a guy from Mexico, I think, that was running a late model Vitara (2-door) with a Dana 30 front end. For what it's worth no matter what pieces you decide on there is going to be a considerable amount of fabrication work to fit it all properly. Several things to consider...
Offline Snoopy
  • Arriba, Arriba, Andale, Andale
    • Cardomain
Re: SAS
« Reply #3 on: April 06, 2006, 02:49:06 PM »
Hi,
It’s been a long time since my last visit and post, Sorry sometimes I really work, though!
Any questions I will be more than glad to help, Indeed I cutter off the Shiite IFS and welded on a tiny D30. It works fine and flex better, it just enough to handle 33 and using stock components, w/ 4.24:1 TC at the end the engine 2.0 and automatic transmission are not really any monster so for now its OK. Couple of u-joints and that’s it.
For the steering I use an Old jeep wagoneer  steering box bolted to the chassis and replace the small tiny  pump by using a bigger heavy duty truck pump, then I ported the box and add a hydraulic assistance piston, works smooth with the ARB on 33.
See you.
Regards / Saludos
Alberto de la Garza
2000 Tracker
