NO START ?????
  • 2575 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
NO START ?????
« on: March 18, 2005, 01:08:43 PM »
MY BROTHER WANTED ME TO ASK A QUESTION FOR YOU SMART FOLKS OUT THERE.... ;D
 HE ALSO HAS A 95 SIDEKICK ITS BEEN RUNNING FINE & THEN TODAY IT WOULDN'T START, TURNS OVER I HELD IT TO THE FLOOR SMELL THE GAS ...SO I'M THINKING ITS A SPARK ISSUE. MAYBE BAD CAP OR SOMETHING???? BUT IT WAS RUNNING FINE THEN NOTHING ??? ANY HELP HE WOULD APPRECIATED....BEFORE HE STARTS PART SWAPPING  ::)
                THANKS MATTY D.  8)
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: NO START ?????
« Reply #1 on: March 18, 2005, 11:51:08 PM »
Could be anything from coil to ECM. Seems to be a rash of ECMs going bad lately...
Offline LawDog
  • 531
    • Emerling Chevrolet
Re: NO START ?????
« Reply #2 on: March 19, 2005, 12:14:50 AM »
Can you hear a little buzzing noise coming from inside the truck when nothing else is on??
  • 2274
Re: NO START ?????
« Reply #3 on: March 19, 2005, 04:48:03 AM »
NO BUZZING NOISE ...AND HE'S GOT SPARK SO...hmmm
« Last Edit: March 19, 2005, 07:13:39 AM by NY_SIDEKICKER »
  • 2274
Re: NO START ?????
« Reply #4 on: March 19, 2005, 07:23:23 AM »
OK SO I FOUND MY HAYNES MANUAL & WENT DOWN TO HIS HOUSE TO CHECK IT OUT......GOT SPARK ...OK SO LOOK INTO THE FUEL SITUATION....DONT HERE FUEL PUMP ...SO CHECK ON MINE I CAN HERE IT FINE...OK MUST BE BAD FUEL PUMP......UNBOLT TANK BRINGING DOWN ON JACK & OF COURSE WITH EVERYTHING IN THE N.E. ITS ALL CORRODED UP IN THERE & THE CLAMPS ARE BEING A PAIN.
 THEN I NOTICE A BROKEN WIRE SO I HOLD IT TO TANK SHAZAM ITS WORKING NOW...HMM WELL LETS TRY WITH OUT WIRE TOUCHING...SHOULDN'T WORK NOW....STILL WORKING..IT WAS THE FUEL GAUGE WIRE ...SO ITS WORKING NOW ??? WILL BOLT IT BACK IN AND SEE.
     GET IT BOLTED BACK IN, DOESN'T WORK AGAIN.....HMMM...TAKE BOLTS BACK OUT, SETTING TANK  ON JACK A FEW INCHES AWAY FROM FRAME IT WORKS AGAIN........ ???  SO THIS IS WHERE WERE AT...WORKS UNBOLTED DOESN'T WORK BOLTED IN. MAYBE A FRAYED WIRE SHORTING OUT OR  ???  ???   ???
                    MATTY D. 8)
« Last Edit: March 19, 2005, 07:25:24 AM by NY_SIDEKICKER »
  • 2274
Re: NO START ?????
« Reply #5 on: March 19, 2005, 07:51:05 AM »
WE DECIDED TO LAY A PIECE OF RUBBER INNER TUBE ON TOP OF TANK ...BOLT IT IN AND ITS WORKING ...FOR NOW ANYHOW. ;D
         THANKS MATTY D. 8)
Offline 90Stomper
  • 427
Re: NO START ?????
« Reply #6 on: March 19, 2005, 09:14:03 AM »
well i went through 2 fuel pumps yesterday so i know how you feel :(  glad to hear you 'solved' the prob. i would say its a pinched wire that is hitting the frame and would be a bit concerned about it breaking, say while your climbing a hill or on an interstate on ramp....
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: NO START ?????
« Reply #7 on: March 19, 2005, 11:26:04 PM »
Mine doesn't start too but does this, seems like it's some kind of relay. Only when It's on contact..... What could it be? Ran really well before Just like NY's Brother's.
ps. Seems to come from behind the fuse box?
« Last Edit: March 19, 2005, 11:27:06 PM by ed-oorklep »
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
