Sidekick problem in a cold start ( S.O.S)
  • 2763 Views
Offline Jecky4x4
  • 22
  • 4x4 for life
« on: October 18, 2005, 01:51:18 PM »
hi guys,
I have an 1992 sidekick 1.6L 16V EFI some time in a cold tep' the engin is not working good it start to shiver & burn to much of petrol, the sparkplags are black from petrol
Anyone can give me a hint where I can look for the problem
Regard
Jecky4x4
« Last Edit: October 18, 2005, 02:45:15 PM by Jecky4x4 »
Re: Sidekick problem in a cold start ( S.O.S)
« Reply #1 on: October 18, 2005, 10:51:13 PM »
I would start with the idle air control valve(under that little black plate of steel on top of the engine) check the plug connection first and clean it,get a used one next and try it out(about 100.00 dollars used 300.00 to 600.00 new.)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #2 on: October 19, 2005, 02:30:56 AM »
Mine shivered after I hadn't driven it for a long time, it was running on 3 (maybe 2) cylinders. after a few minutes of driving it went away.... Maybe check if you have spark? Otherwise try mrfuelish's approach  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline b1pig
  • 61
    • Jeep
« Reply #3 on: October 19, 2005, 04:32:48 AM »
you have black smoke from the exhaust?
b1pig
'90 Tracker, '07 JK Rubi
Offline Jecky4x4
  • 22
  • 4x4 for life
« Reply #4 on: October 19, 2005, 12:04:21 PM »
yes thar was a black smoke from the ex'
Offline Jecky4x4
  • 22
  • 4x4 for life
« Reply #5 on: October 19, 2005, 12:08:50 PM »
can you show the location of the air control with a photo?
