Lockright Rear Locker
  • 1805 Views
Offline darkd
  • 19
    • offroadfun.de
« on: October 21, 2005, 02:45:40 AM »
Hi there,
This is a question to everybody having installed a rear lockright to a Sidekick.
Mine is late 89. Installed a Lockright a few month ago. Already had one in my Samy before.
My question:
When u have your transmission in neutral position, how much of bearing play have u got when trying to turn the cardan shaft by hand?
I´ve got about 45 degrees from stop to stop.
Is this normal?
I ordered mine from rocky road and when fitting it into the diff housing the locker was about 1/3 inch smaller in diameter then the inner side of the diff. ???
(Hope u understand what I mean...)
Thanx
Daniel
Suzuki Sidekick 1,6 8v Supercharged
www.offroadfun.de
We don´t need any Roads!
Re: Lockright Rear Locker
« Reply #1 on: October 21, 2005, 06:34:05 PM »
Lockers create a lot of play like that,
the question is, does it work ???
Offline darkd
  • 19
    • offroadfun.de
« Reply #2 on: October 22, 2005, 01:02:57 PM »
Hi,
sure it works. It was not 45 degrees. Just about 20.
Just had a look at the manual. They write its normal like that.
Thanks
Daniel
www.offroadfun.de
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: October 22, 2005, 03:11:02 PM »
if i get a bt of back lash in my diff it seems to show throught the prop so i have to adjust it at least once a rear ,  but seems normall
Markyb (UK)
UK Vitara JLX SE
