Oil Pan Change In 94 Sidekick 8 Valve
  • 2366 Views
Offline BlackSS05
« on: October 21, 2005, 03:40:14 AM »
I was wondering how hard it is to change the oil base pan on my 94 Sidekick 4wd 8 Valve.  Do you have to lift the engine out or take the crossmember down to get at the pan?
Thanks
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Oil Pan Change In 94 Sidekick 8 Valve
« Reply #1 on: October 21, 2005, 03:26:25 PM »
I think the diff gets in the way a bit.  May need to lift the engine.  It's been a long time since i've done it.
1993 4-door Sidekick
4.24:1 t-case
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: October 21, 2005, 04:41:22 PM »
Maybe a good time to remove you front axle and change the seals  ;D
« Reply #3 on: October 21, 2005, 06:27:18 PM »
I had to drop the front axle housing,
remove the center link and the CV shafts
and then you can just barley get it off
by removing the oil pickup bolt so the
pan will slip out from between the frame
and the engine.
I think it would be easier to pull the engine
instead of laying on your back for 5 hours
Offline zaggy
  • 1134
« Reply #4 on: October 21, 2005, 09:13:22 PM »
Don't you just hate being right all the time Wild. LOL
     I have to go along with Wild on this one, it's easier out and you are less likely to screw up and get a leak.
Zag
« Reply #5 on: October 22, 2005, 06:53:03 PM »
Well, I think I've tried every "short" cut
and most of them take longer, I only tried
to fix my oil pan leak 3 times, 3rd time was
the charm, and forget the crappy cork gasket,
just go get some Ultra Grey Silicone, and glue
that pan on, no leaks and it won't start in 2
years like the cork one will.
