Newbie needs some help with lift
  • 10 Replies
  • 4083 Views
Offline lacrosse10604
  • 50
« on: October 22, 2005, 01:33:44 PM »
Hey. I'm looking at doing this poor man's lift:
http://www.zuwharrie.com/content/view/11/27/1/0/
Where can I get these parts to make it?
Thanks!
Dave
Searching for a donor for my diesel build.
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Newbie needs some help with lift
« Reply #1 on: October 22, 2005, 02:26:17 PM »
Talk to Digger here, he can get you coil spacers actually made for the Tracker/Kick.
As for the stuff for the body lift, any GOOD hardware should have most of it.  Home Depot...maybe.  Check the phone book for steel/iron/metal sellers and fab shops, they could point you in the right direction.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: October 23, 2005, 09:55:24 AM »
Thanks!
Dave
I bought Jeep TJ 1.75" coil spacers - $120(2 sets of a pair)
-trimmed the two front ones to 1.25" to achieve 2" lift.
Bought 3x3x3x48 square tube from a demolition yard - $9
Cleaned it up with a grinder, had it cut at a metal shop - $11
Drilled holes - free
Painted blocks black - free
I haven't bought bolts yet, but they'll be less than $20
  • 50
« Reply #3 on: December 12, 2005, 05:11:14 PM »
So here are the costs for future reference:
3" Blocks from a Steel supply - $40
Nuts & bolts from Ace - $20
1.75" Spacers from Digger (Neil) - $50
Total: $110
Someone can probably do this cheaper but that's what it cost me.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #4 on: December 12, 2005, 07:26:58 PM »
strut spacers might be helpful with the strut flip.   stan
Offline aceluck
  • 30
« Reply #5 on: December 13, 2005, 09:42:22 AM »
Thanks!
Dave
Does anyone know if this lift works for 1999-2004 Trackers/Vitaras and what differences, if any, there are in the process?
Aslo, in http://www.zuwharrie.com/content/view/11/27/1/0/ , I can't see any of the pics. Is everyone else having this problem?
Thanks in advance.
Offline the_maplebar
  • 466
« Reply #6 on: December 13, 2005, 12:44:41 PM »
No pictures for me either.  Heather's club (where the pics are hosted) apparently changed their links.  You can find a copy of the article with pics there.
http://www.granitepath.com/~irving/suzuki/budgetbodylift/index.htm
You can do coil spacers and a body lift on the 99-05 models, but there are a few differences.  I have heard that the dimensions on the coild spacers & lip etc. changed a little bit from the sidekicks to vitaras.  Also the 99+ model have a strut tower brace that prevents you from being able to flip the strut for additional down travel.  You will need either longer struts (OME makes a set http://www.rocky-road.com/kickome.html) or strut spacers.  JDMCRX is fabbing up a kit with coil spacers and strut spacers made specifically for the 99+ models.  http://www.zukiworld.com/forum/index.php?topic=8494.0  But the cost is a little more.
The body lift will be a little different too, the main problem is the rack & pinion steering.  You will probably need to extend the steering shaft with something like RRO has http://www.rocky-road.com/kicksus.html
For a good walkthrough on an XL-7 (with lots of pics) see Nomaad's writeup.
http://www.carneyco.com/ProjectNomaad.pdf
And don't forget that there is a forum on Zukiworld dedicated specifically to the 99-05 models
http://www.zukiworld.com/forum/index.php?board=10.0
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: December 13, 2005, 10:39:04 PM »
Thanks for posting the link to our site. Yes, a while back we did change the links, and I'm not sure why Zuwharrie's pictures don't show up, except that I guess they aren't hosting them and are linking to our site. That's ok.
I guess I need to let them know. ;D
Also, this reminds me I need to update our site some.
Pic from tonight, just because:
Heather Galvin
Offline aceluck
  • 30
« Reply #8 on: December 14, 2005, 07:50:37 AM »
Thank you for that detailed and thorough reply! :)
Pierre
  • 6598
  • 68
« Reply #9 on: December 14, 2005, 10:48:12 AM »
Is that the HP parking lot in Boise? :)
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: December 14, 2005, 12:31:22 PM »
Nope, the Fiberpipe parking lot in Boise. (Nate's work)
 ;D
Heather Galvin
