Anvil
  • 1922 Views
Offline legionnair
  • 94
  • I hate working lets go wheeling
Anvil
« on: October 23, 2005, 02:18:38 AM »
Do you guys know if you need to use the GV third member
or can you get away with using a stock sidekick third member
thanks Dustin
OOps, owell thats just the fender
Offline jagular7
  • 1026
  • Jagular7
Re: Anvil
« Reply #1 on: October 23, 2005, 06:40:23 AM »
Based on the research I've done for a steel front housing, any front 3rd member housing shall work. However, the Trackick housing will be aluminum and have a way of attaching to the frame. The Vitara model can be cast steel or aluminum and will have a different frame attachment. Both are said to be 7" ring gear diameter.
Zukipilot used a cast steel XL7 (Vitara model) 3rd member housing with his Anvil. There is an article in the article archive.
Lenexa, KS
mudfkr
Re: Anvil
« Reply #2 on: October 23, 2005, 01:58:22 PM »
You could use the stock alloy sidekick one but that kinda defeats the purpose of the anvil.
With the alloy one youd still be leaving a weak point in there. If you did decide to use the sidekick one youd still have to  make sure yours has a 26 spline inner axle not a 22 spline and if not you'd have to find 26 spline side gears and inner axle to match then change it over.
Re: Anvil
« Reply #3 on: October 23, 2005, 03:16:14 PM »
I have a GV steel front, I used the 5:83s from my old shape Track/Kick/Vit in the GV diff so the sizes are indeed the same. The GV third member mounting is the same as the Track/Kick, the XL7 is different. I kept the air actuated diff so i have 2wd low.
