what do you think about a winch?
  • 2134 Views
Offline samuraiVT
  • 89
« on: October 24, 2005, 12:03:06 PM »
well i was planning on getting a 3500lb atv winch for my sami but i was just wondering if you thought that would be enough winch or not? if not how big should i go?
88.5 samurai 8in springover lift 32x12x15 firestone RMT's on black rockcrawlers lockers front and rear with auto tracker seats sidekick gears custom bumpers front and rear spray in bed liner soon to come winch, paint, top,  hopefully a 1.6l swap full roll cage and some other
Offline bandit86
  • 1641
  • elv8rguy
Re: what do you think about a winch?
« Reply #1 on: October 24, 2005, 01:11:35 PM »
I just got a 4000lb for my tracker.  I got it cause it's lightweight, I dont have a whole lot of power with the 1.6 to play with
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: October 24, 2005, 02:13:09 PM »
If you use a snatch block, and double the cable back to your car, then you'll effectively double the capacity of the winch, reducing the strain on it.
The single line pull capacity will be 3500lb, and a double line will be close to 7000lb.
I think this would work just fine for you, unless your 31" tires are completely stuck in the mud, then you may not get unstuck with the winch alone.
1993 4-door Sidekick
4.24:1 t-case
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: October 24, 2005, 02:47:02 PM »
The general equation I've heard when dealing with bigger trucks is 1.5 times the weight of your truck as you intend to use it.  So for most fullsize trucks weighing in around 5000lbs a 9000lb winch is good.  For a 2-3k Suzuki I'd think a 3500lb winch would work, but I don't know if there are any internal differences to consider.
Considered a 6k winch?
Offline samuraiVT
  • 89
« Reply #4 on: October 24, 2005, 03:19:43 PM »
well has anyone had experiance with a 3500lb winch i dont plan on getting in stuff to bad but who knows
Offline darnold87
  • 351
  • 11
« Reply #5 on: October 24, 2005, 05:39:47 PM »
I feel you can't really go too big with winch power.  I have saved myself and many others with my 8274.  It's not good to strain a winch - it leads to having to rebuild the electric motor, which isn't too hard, but annoying...
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
Offline ksa421
  • 382
« Reply #6 on: October 24, 2005, 07:26:45 PM »
I have a 8000lb warn winch and I ripped my bumper off once trying to pull a guy out. It difinetly had enough pulling power for my sidekick. Dang near pulled it over on it side oncee pulling at an angle in the snow. ;D
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #7 on: October 24, 2005, 07:47:24 PM »
Be sure that it has an internal brake. A lot of atv winches do not have one.
Mike
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #8 on: October 24, 2005, 10:19:34 PM »
I used a 3000lb Milemarker on Silver and it worked great for it. The only issue I ever had was snapping the cable, but that was my fault, shock loading it across a rock... ::)
