SPOA Instal Questions
  • 1776 Views
Offline blyota91
  • 71
« on: March 16, 2005, 10:30:12 PM »
Well I was working on putting in my lift last night and ran into a few problems that aren't addressed in the instructions.  First  I have the spidertrax spoa kit, and I have no idea where to put the front bump stop plates they provide, does really say, or how to position them.  Second I got the big tall ford front shock towers, where do I position them, I'm assuming you just cut out the stock ones and put them in there place.  Third and final I think, I got the rocky road ott stage 2 steering setup and one of the new knuckles doesn't line up quite right so I can't get the caliper bracket on, I was thinking just enlarge the holes a bit to get it to fit through, what do you guys think.  Other than that I am very happy.  I think I am going to email spidertrax and suggest they elaborate the instructions as far as those shock towers and the bump stops for the front.
Andrew
1988 Samurai 5inch SPOA and 32X9.5 TSL's  Giggity Giggity
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: SPOA Instal Questions
« Reply #1 on: March 17, 2005, 12:04:43 PM »
I also used f-250 towers. I ended up cutting off 4" off the bottom and birdmouthing them halfway up to tip them out off the frame some. I run 32"? long doetsch tech shock with my own lower shock mounts.
The bump stop plates that I think you have go in between the stock bumpstop and the mount, but it's easy to just give them a call.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline blyota91
  • 71
« Reply #2 on: March 17, 2005, 10:18:58 PM »
I'm not sure on the length of my shocks it must be close to that, I probably will give them a call to figure out where those fit and how to get the shock mounts in, anybody else know?
Andrew
