Code 15, changed sensor Code 15 AGAIN???? whats goin on here>?
Festiva
92
I Love ZUKIWORLD!
October 27, 2005, 10:24:44 AM »
Hi guys, i pulled a code 15 on my tracker, went to pepboys $35.00 later, after i put the sensor in im driving along light comes on code 15 again...
Anyone have any idea what the heck could be going on here? did i get the right sensor?
its a 94 8valve and the sensor that they gave me is the lower on the intake with a 2 prong connector.
thanks for your help!
Jason
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: Code 15, changed sensor Code 15 AGAIN???? whats goin on here>?
October 27, 2005, 10:42:52 AM »
Code 15 = Water temperature Sensor High Temperature.
You will get this if the sensor is shorted to ground. You may have a wiring problem.
Last Edit: October 27, 2005, 10:55:42 AM by Rhinoman
http://www.rhinopower.org
derekj
784
i'm the canadian guy eh?
October 27, 2005, 01:28:29 PM »
check the resistance of both wires in the circuit from the sensor to the ecm to determine if it has ashort in the wiring
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
Festiva
92
I Love ZUKIWORLD!
Reply #3 on:
October 28, 2005, 08:16:00 AM »
Rhinoman, thanks for the picture!, the WTS is the part i changed, i guess i will have to check the wiring!, Does anyone know what the reading should be on this sensor to test it? mine old one might still be good.
thanks!
wildgoody
8134
67
Reply #4 on:
October 28, 2005, 08:23:38 AM »
I have a table that shows the temps and
readings, this sensor varies by temp
I'll have to look for it
Rhinoman
4502
36
Reply #5 on:
October 28, 2005, 09:08:35 AM »
Here is a chart I generated of the resistance characteristics. You'll need to save it somewhere and then open it to get full size.
Last Edit: October 28, 2005, 09:11:29 AM by Rhinoman
