fuel pressure reg question
  • 2105 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: October 28, 2005, 11:36:02 AM »
Where is the fuel pressure regulator located on a 91 kick? As long as it is not in the tank, I'm good. Lookin to run a fuel cell and external pump. Also, what pressure does the system run at?
Thanks!  8)
Re: fuel pressure reg question
« Reply #1 on: October 28, 2005, 12:11:22 PM »
Its on the front of the throttle body. Fuel pressure is around 38 psi, to be precise 265kPa above the pressure in the throttle body itself.
Offline Chief
  • 678
« Reply #2 on: October 28, 2005, 02:23:58 PM »
Excellent! Exactly what I needed to hear! Thanks!
Also, what is the pump rated at, PSI wise? Found a MSD fuel pump, but it is rated at 120 psi. Wondering if that would be a problem.
« Last Edit: October 28, 2005, 02:52:17 PM by Chief »
« Reply #3 on: October 28, 2005, 06:12:51 PM »
My tested fuel PSI was at 36 PSI, and
a higher capacity fuel pump (PSI wise)
will not matter, the pump supplies the
fuel and flow, the regulator "regulates"
the PSI. The stock fuel pump will supply
about 60 PSI before it's internal blow off
vents the pressure
Offline Chief
  • 678
« Reply #4 on: October 29, 2005, 10:39:14 AM »
vents the pressure
Good, thanks for the info Wild. Gettin a 8 gal Summit Racing fuel cell, the MSD pump then I Just have to get it all plumbed together and cut the rear "bed" out and slid it down in there to open up underneith to slid the axle back about 8".  8)
