Manual Tranny Lub for A/T??? HELP PLEASE!!!
  • 1945 Views
Offline PYRO
  • 16
« on: November 02, 2005, 01:21:06 PM »
The spec the link below describes the lub to use on Manual and Auto tranny and is the same!!! :o, I'm confused, Isn't auto tranny lub different (less weight) than Manual? Will it do any harm to an Auto Tranny to run with manual tranny lub?? Is manual lub better for hardcore wheeling with auto tranny, please with your knowledge could you recommend what lub should I use for my next A/T oil change. I got a 92 Tracker, 3 speed A/T and is doing estrange shifting when I turn, or after highway drive, it seems to slip on 1st.
Thanks
http://www.zookpower.ca/fluidspecs.html
Offline SnoFalls
  • 1358
Re: Manual Tranny Lub for A/T??? HELP PLEASE!!!
« Reply #1 on: November 02, 2005, 02:06:19 PM »
don;t believe everything you see on the internet ... ATF fluid for your auto tranny
« Reply #2 on: November 02, 2005, 03:14:51 PM »
Dexron III is what you want for ATF, there are different ones
Offline PYRO
  • 16
« Reply #3 on: November 02, 2005, 03:27:25 PM »
Dexron III will be then!!!!  ;D
Thanks!!!!
This is a great Site!!!!! ;D
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #4 on: November 03, 2005, 11:30:45 AM »
Not that it applies here--Some manual trannies are specified to use ATF.
« Reply #5 on: November 03, 2005, 08:57:12 PM »
That's true, as well as some T-cases
