wheels
  • 1894 Views
Offline cruisers4wdtoy
wheels
« on: November 04, 2005, 03:02:23 AM »
Will 31-10.5-15 BF Mudd Tires fit on the stock wheel 91 Tracker? ???
Offline Dihnekis
  • 398
Re: wheels
« Reply #1 on: November 04, 2005, 05:34:43 AM »
I'd liek to know also, will any 31" fit on the stock tracker wheels? I'm thinking about using it for a spare on my sammy.
1988 Suzuki Samurai
Re: wheels
« Reply #2 on: November 04, 2005, 03:47:29 PM »
It would probably fit but the stock Zuk rim is really far to narrow for a 10.5" tyre. Usually the manufacturers recommend at least an 8" rim for a 10.5" tyre. The stock Zuk is only 5.5". I have a BFG fitment guide on my site under Tech Info
http://www.rhinoman.org
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: wheels
« Reply #3 on: November 04, 2005, 07:02:01 PM »
Will it fit?
Yes.
Will it work?
Yes.
Is it recommended by the tire manufacturors?
No.
A better choice would be some 7" or so wide rims but eh, if this is all you have it will work for a while.  Keep in mind the 31's will definately rub something with that much backspacing and the air pressure you'd need to run would be low...but still perfectly suitable for a light weight rig like a Suzuki.
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
Re: wheels
« Reply #4 on: November 04, 2005, 10:40:42 PM »
Yes 31x10.50's do fit on the stock rims but front tires rub the frame at full lock and as the rear flexes they rub on the top inside of the wheel well. That is what I'm running now, been slowly building on a budget so new wheel rims come later.
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
