my 1991 sidekick is getting fuel to the injector but will not spray fuel orstart
  • 3463 Views
Offline ffuller
my suzuki sidekick 1991 throttle body injection is getting fuel to the injector but it will not start.
the injector reads the correct ohms any sugestions?
http://www.suzukiinfo.com
They have a scan of the FSM with lots of diagnostic stuff
Offline zaggy
  • 1134
Those symptoms are common with a failed ECU....
- You have fuel pressure?
- You have spark?
- Haven't recently had any valve timing problems?
If you have checked all that stuff and it's ok, I would bet it's the ECU
Zag
Offline ffuller
i have checked the fuel and it is pumping fuel to the injector and the zuk will start if you put gas in the throttle body. but the injector will not spray fuel.
Offline ffuller
i dont have a gage or know where to hook it up so i dont know if it is getting enough pressure but it pumps a lot of gas.
We regret to inform you your ECU has died.   :'(
Offline zaggy
  • 1134
Yes Dr. Wildgoody........I must concur.
Zag
You might have a break in the wiring, Check the connector to see if you have 12V on one pin.  Check the wiring back to the ECU for continuity.
Have you tried pulling codes from the ECU? you should get a Check Engine Light if the circuit is broken.
Try connecting the injector, very briefly, across the battery and see if it will squirt then.
« Last Edit: November 06, 2005, 10:33:19 AM by Rhinoman »
Offline RJkick
  • 634
Unfortunately, I had a similar issue and indeed it was the ecm
Surly from the board does good work at a reasonable rate and in a few days.
