O rings
  • 2526 Views
Offline karl214
  • 228
O rings
« on: November 07, 2005, 02:13:06 AM »
Does anyone know where i can buy the O ring that goes on the pipe off the back of the waterpump?? I've tryed autozone and advanced auto no luck there.. Went to napa found some but they don't seem to be right as the pipe still leaks coolant..
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
Re: O rings
« Reply #1 on: November 07, 2005, 07:25:54 AM »
You should be able to use generic O-rings,
match the size of the tube as well as the size
of the ring matierial, and a little tight is fine,
better stretched than loose, and use a light
coating of silicone in the water pump inlet to
help seal those leaks, the silicone should make
a small buildup as the tube slides in, as well as
it helps slip it all together easy
Offline karl214
  • 228
Re: O rings
« Reply #2 on: November 07, 2005, 01:04:51 PM »
Well that seems to be my problem, can't seem to find the right thickness...
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: O rings
« Reply #3 on: November 07, 2005, 01:44:48 PM »
Three words:
Hawk Strictly Suzuki
Ack
Offline takai
  • 907
Re: O rings
« Reply #4 on: November 08, 2005, 04:36:46 PM »
Three words:
They would have it. Just ask for John at the parts counter. He will take good care of you.
'Cause, I am to misbehave.
