VIN number locations
  • 2193 Views
Offline alfonse
  • 17
« on: November 07, 2005, 08:32:01 AM »
I could use some help.  I have an 87 Sami that the VIN on the dash doesn't match the title.  However,  both VINS are registered to the same guy I bought it from.  I suspect he had a parts rig and it is a mix.  Where is the VIN on the tub or frame so I can check it as well?
Thanks,
Alfonse
Offline Gary_Hill
  • 288
Re: VIN number locations
« Reply #1 on: November 08, 2005, 03:53:20 AM »
Passenger side wheelwell frame rail, You may have to scratch off some paint or undercoating.
I suspect that the previous owner swaped the dash out for some reason.  As long as the tags match the frame rail you should be ok.  You could remove the missmatched tag on the dash without much harm. I believe there is another  VIN number stamped on the body somewhere. DMV will know where it is.
It would be better to straighten the VIN #s at the DMV instead in front of the judge.
        Good luck with that...Gary
Offline Gary_Hill
  • 288
« Reply #2 on: November 08, 2005, 04:00:12 AM »
I think Gary Monk at Petroworks.com sell a great aftermarket metal dash  for Sams...has one on his personal Yellow Sam. Thw speedo cluster pops right in and has cut outs for after market guages.
