Battery post too small for clamp.
  • 4175 Views
Offline keith
  • 1176
« on: November 08, 2005, 07:19:09 PM »
The battery that I have had in my Tracker for the last year and a half has a positive post that is sized such that the clamp on the cable doesn't tighten really tight.  I can rotate the connection when it is tightened.  This hasn't presented a problem until today.  I stopped for lunch and when I went back to the truck it make a single click and wouldn't start.  I tried turning the key several times but no crank.  Then I popped the hood and wiggled the cable.  It started right up.  I think that the cable has oxidized enough to interupt the loose connection.  My question is how can I make better contact without replacing the battery or the cable?  It looks like the cable goes into a wire harness and would not be an easy swap.  The clamp to post connection is snug, but not tight.
Re: Battery post too small for clamp.
« Reply #1 on: November 08, 2005, 07:29:34 PM »
Remove the old clamp, they do corrode and get loose,
and replace it with a Marine battery clamp, you can get
those loose with your fingers, they have a thumb screw
and a lever to tighten, add some battery washers to help
with the corrosion around the terminals and be a happy
Zuker again, you can also replace the Neg terminal too
Offline keith
  • 1176
« Reply #2 on: November 08, 2005, 07:33:19 PM »
So I can just cut off the current clamp and screw on the marine one?
« Reply #3 on: November 08, 2005, 07:35:07 PM »
Ya, the new one will have bolts and nuts
to clamp it onto the old cable, I've used
these for about 5 years now, AutoZone
sells them, along with other parts stores
