Power Steering In a Samurai Survey
  • 18 Replies
  • 7872 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« on: March 12, 2005, 11:45:38 AM »
I was looking through all the gear guide web sites to see who sells kits for power steering for the Samurai.
Then I had a great idea!
I thought I would ask the real world their opinions, just to see what is out there and what other people have done.
I'm looking for a cost effective method for power steering.
So if you have power steering what did it come off of?
What parts did you have to buy / make for it to work?
Where did you get the parts from?
And most importantly how much did it cost?
Thank you for you time,
  Bash ;D
« Last Edit: March 13, 2005, 04:44:48 PM by bashzuk »
Mean Green Wheeling Machine
Offline ROSS
  • 1412
Re: Power Steering Survey
« Reply #1 on: March 12, 2005, 12:06:29 PM »
I'M HAPPY WITH MINE. I BOUGHT THE SIDEKICK ADAPTER FROM CALMINI. THE PUMP AND STEERING BOX FROM HAWK. IT'S ALWAYS WORKED GOOD FOR ME
                                             ROSS
Offline locjaw
  • 2045
  • 22
« Reply #2 on: March 12, 2005, 12:09:15 PM »
did kick p/s on my sammy havent had any problems but would have been cheeper to go yota p/s. yota is probably stronger. both will require mods(drilling, welding) to the frame for install dont beleave in mixing suzy and yota. I have both but I keep the yota parts on the yota and the zuk parts on the zuk, but that is just my pet peave.
jason
Offline ROSS
  • 1412
« Reply #3 on: March 12, 2005, 12:14:04 PM »
CALMINI HAS A ADAPTER THAT REQUIRES NO DRILLING AT ALL . BOLTS RIGHT ON.
                                  ROSS
Offline mesjr2004
  • 422
« Reply #4 on: March 12, 2005, 12:48:47 PM »
i have a toyota ps box on my sas tracker but it would the same setup on a samy , i had to drill and tap some 3/4plate for the box and weld it to the outside of the frame,cut some of the inner fender out for the steering shaft and the ps lines , i used a tracker pump ,skys crossover steering , it workes great and the extra length uf the drag link helps with the angles of the link and bumpsteer. i looked at a lot of boxes and the toy ifs 4x4 box worked great.
« Reply #5 on: March 12, 2005, 03:24:51 PM »
I used a 1994 kick box and pump with the stock 1.6 bracket.   It would be cheaper for you to find a wrecked tracker for all the parts you need and could use, like the 1.6 engine,brakes,gears and housing,power steering,radiator,trans and tranfer case for a kicker three, ect. most of the steering kits go for about four hundred bucks.
Offline bhaugen
  • 140
« Reply #6 on: March 12, 2005, 04:57:58 PM »
Powersteering out of a Tracker.  Kit from Trail tough.  Requires some drilling, but goes together good.  I am happy with it.
BTW in a Sammy.
« Last Edit: March 12, 2005, 04:58:20 PM by bhaugen »
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #7 on: March 13, 2005, 12:38:44 AM »
I ran kick/track ps for about 6 months. I got rid of it. I run 35's on beadlocks at 2psi and a locker in the front. The kick stuff couldn't handle it. I know that this setup is not your standard Sammi setup but I thought I would share in case you have aspirations to run 35's. I'm currently in the middle of a Hydro assist install. YOu can read about it here:
http://bbs.zuwharrie.com/content/topic,15885.0.html
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
« Reply #8 on: March 13, 2005, 01:45:07 AM »
Id have to agree with NC. If you are gonna run big tires do something other than the kick setup. I run it on my little sami (31's)and am very happy. I wouldnt run it on anything above 33's myself.
Offline bashzuk
  • 784
« Reply #9 on: March 13, 2005, 04:39:10 PM »
I was looking at the Rocky Road Toyata Steering setup and was wondering how could a car power steering pump be stonger than the track/kick pump?
Any thoughts on this.
Here is the web site
http://www.rocky-road.com/powersteer.html
Offline nc_zuk
  • 406
    • www.samurai4x.com
Re: Power Steering In a Samurai Survey
« Reply #10 on: March 13, 2005, 09:30:48 PM »
Is a Kick any bigger than a car? I mean seriously, they are about the same size and run the same size tires in the stock configuration.  :-/
Offline TomKat
  • 211
« Reply #11 on: March 13, 2005, 10:33:46 PM »
I ran last year a Toy IFS setup from a 4-cylinder. Worked good but stalled a bit in big rocks.  This year I'm going to a saginaw TC pump and a Toy FJ-60 box. If that stalls, here comes hydro assist. As for the bracket on the engine, I just modified the stock toy pump mount to fit my 1.3l. The frame mount was easy, just sleeve the frame for the mount bolts and weld  a 1/4"plate to the outside.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline DaddyDave
  • 204
  • Indeed
« Reply #12 on: March 14, 2005, 12:40:44 AM »
Kit from CALMINI, stock parts from Hawk.  The whole kit installed in about an hour and a half and I wouldn't go back if you paid me.  The kit is so very simple to put together.
Offline zukatude
« Reply #13 on: March 14, 2005, 03:30:59 AM »
Land Cruiser FJ60 steering box ($80) and Saginaw TC pump from an '04 TJ($65).  Also used spidertrax pulley and mount, both very nice and mounted without issues.  The hi-pressure hose is custom made from both of the old ends at my local tubes-n-hoses (IIRC about $35) store.
The FJ60 box requires plating both sides of the frame and sleeves for the holes.  Got a short drop pitman arm from Sky and using his x-over steering for toy axles.
Did the saginaw pump mod for flow and used a tranny cooler.  Seems to work very well, but if you are working the pump hard, it will kill my stock 1.3 at idle ::)
Note to self: get more torque ;D
-Paul
87 Sammi: YJ SPOA SR on locked 5.29 toys, 35" MTR, 6.5 tcase, Warn M8k
  • 6598
  • 68
« Reply #14 on: March 14, 2005, 03:59:34 AM »
Ya know, I run the Sidekick set up on my ol red Samurai with the Dana 44s and the 35 TSL/SX's. It works really well. The reason I have had good luck, I believe, is there are different Sidekick pumps. Some are smaller /weaker.
