Removing t-case from Tracker
  • 2325 Views
Offline ADavis
  • 209
    • Aaron's Webpage
« on: March 13, 2005, 02:41:32 PM »
Hey all, I'm going to be pulling the t-case from my tracker and I was wondering if I can pull it easily without pulling out the transmission?  I  have the Dealer Manual and it says to pull everything, but I would prefer not to.  Thanks for the info.
Aaron
Aaron
Offline Natebert
  • 1098
Re: Removing t-case from Tracker
« Reply #1 on: March 13, 2005, 02:51:34 PM »
Unless you can access the bottom of your shifter assemply on top of your tranmission and have already removed the bolt, I'd say no.  You'll need to remove both together.
~Nate
Offline 90Stomper
  • 427
« Reply #2 on: March 13, 2005, 02:54:23 PM »
removing the tcase w/tranny is easy, its not as heavy as you might think.  getting it  back on is a lil harder, it will be alot easyer to do your work with it off.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #3 on: March 13, 2005, 03:19:29 PM »
Thanks for the info.  I appreciate it.  Do you use a trans. jack or can it be easily done with a regular jack.  I know on my early bronco, it was very heavy(T-18) and almost impossible without a trans. jack.  Thanks for all the help.
Aaron
Aaron
« Reply #4 on: March 13, 2005, 04:32:17 PM »
Without a bodylift its not as easy but it is nice and light ;D
There is a bolt right under the Tranny shifter. you have to remove the Tranny shifter to access it. Thats where a body lift comes in handie ;D
« Last Edit: March 13, 2005, 04:37:46 PM by trickker »
Offline 90Stomper
  • 427
« Reply #5 on: March 14, 2005, 05:04:38 AM »
i have done it with and w/out a trans jack.  with the jack is much easyer!  its not heavy but it has no flat spots on the bottom either.  got a cheepy one for $45 at harbor freight since i dont use it everyday, worked fine.  spend $4 on an alignment tool and two 8" bolts that are the same as the top 2 that go into the engine, to be used for alignment at install.  be patient and good luck. ;)
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #6 on: March 14, 2005, 01:56:14 PM »
Thanks for all the input.  I ordered the t-case today with the gears, so hopefully I can put it in within the next couple weeks.  Can't wait to wheel with the lower gears ;D
Aaron
« Reply #7 on: March 14, 2005, 04:35:29 PM »
The nice part about the T-case gears is you can actually up shift going up hills ;D
I can take hills in 3rd gear ;D
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: March 15, 2005, 12:07:49 AM »
Just a FYI:  Most people do not put that top bolt back in - EVER.  That way, you can drop the tcase by itself in the future.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
