leak from under dash
  • 2839 Views
Offline nutergav
  • 10
« on: November 20, 2005, 09:49:13 PM »
Hey all.
I have a water leak coming in from somewhere under the dash on both the passenger side and the drivers side.  I can't seem to locate it.  It only happens when its raining so its not anything leaking from the car.  Also, i find it leaks much more on the passengers side that the other.  It comes out more when we go around corners but it still comes through when it is stationary.  Any ideas???
Cheers, Gavin
leftfield
Re: leak from under dash
« Reply #1 on: November 20, 2005, 09:51:55 PM »
what are you driving
Offline nutergav
  • 10
« Reply #2 on: November 20, 2005, 09:57:51 PM »
oh sorry,
I am driving a Sierra 1993.  I think its the same as a Samuri 1993.  Not sure.
Gav
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #3 on: November 21, 2005, 02:44:32 PM »
Replace the seal on the lower edge of the windshield.  That's gunna be the problem no doubt.
1993 4-door Sidekick
4.24:1 t-case
Offline nutergav
  • 10
« Reply #4 on: November 22, 2005, 05:22:46 PM »
cool.  thanks man.
I think that the window was just recently put in though.  I'll have to get whoever put it in to have a look at it again.
Cheers, Gav
Offline Cwkick
  • 888
« Reply #5 on: November 23, 2005, 10:23:23 AM »
nutergav,
crikeymike is not talking about the windshield seal itself.  Between the window frame and the body tub there is a seal.  They will fail after a while.
Cwkick
mudfkr
« Reply #6 on: November 23, 2005, 11:17:04 AM »
nutergav,
Cwkick
that's only if it a soft top which he hasn't said.
Moore_power
« Reply #7 on: November 23, 2005, 11:35:25 AM »
I'm having the exact same problem with mine (87 Samurai soft top).  I'm getting ready to take the windshield frame off this weekend.
Will weatherstripping from home depot work or will I need something special?
Offline crikeymike
  • 713
« Reply #8 on: November 23, 2005, 03:11:34 PM »
you can do a double layer of weatherstripping, just can't put in too much cause when you go to close it up, then you can stress the whole frame out from pushing/pulling it too hard.
4.24:1 t-case
