Backup light problem
  • 2448 Views
Offline Moallen
  • 68
« on: November 22, 2005, 03:47:00 PM »
Hello all,
            I have a problem with my backup lights on my 1987 samurai. The backup lights only come on when I go to 5th gear.No backup light in reverse. Very strange. Any master electronics guys on here?                        Thanks  Allen
1987 Samurai 32" front and rear lockers 1.6 engine spring over lift 512 gears
2005 dodge dually 4x4 diesel
98 Jeep
1989 34' Stamas twin 225
20' Sea Ark boat 1989 toyota (beater car)  two cobra kayaks 28ft classic car haul kubota L2900 tractor
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Backup light problem
« Reply #1 on: November 22, 2005, 04:11:19 PM »
someone has put the wires for the reverse lights onto the 5th gear switch on the tranny.  There's a funny little switch thingy that plugs into 2 positions on the tranny, 1 for 5th gear (i believe), and the other for reverse.
Someone been screwing around under there.
1993 4-door Sidekick
4.24:1 t-case
Offline Moallen
  • 68
« Reply #2 on: November 24, 2005, 08:16:06 PM »
HI,
     Thanks Mike I will look at that.              Allen
98 Jeep
« Reply #3 on: November 24, 2005, 08:27:56 PM »
if nobody has cut wires just pull out both switches and swap them back where they belong,the front one you can change from under the hood.
Offline Moallen
  • 68
« Reply #4 on: November 26, 2005, 09:17:33 AM »
OK,
         But can you tell me where they are located on the samurai.         Thanks   Allen
98 Jeep
Offline wildcat
  • 11
  • Verry funny Scotty. Now beam down my clothes!
« Reply #5 on: November 26, 2005, 10:30:44 AM »
They should be on the firewall right behind the carb (if same as my 89) they should be the only 2 that run down to the tranny.
89 Sami
Yota axles welded rear
33" Baja Claws
« Reply #6 on: November 26, 2005, 11:30:23 AM »
They are both on top of the transmission,if your sitting in your rig they should be on the top left side.
Offline Moallen
  • 68
« Reply #7 on: November 26, 2005, 03:13:56 PM »
Hello,
          Thanks guys, you are life savers!! I will go look and see if the wires are reversed.
        Allen
98 Jeep
