got a ?
  • 2025 Views
Offline mlovetripp0
  • 204
  • do more with less
got a ?
« on: November 23, 2005, 06:07:10 PM »
will sidekick ring and pinion work in 87 zuki .i was told by a friend that a tracker/sidekick r&p will fit and that there 5.12 to 1 is this right?
87 sammi
Offline locjaw
  • 2045
  • 22
Re: got a ?
« Reply #1 on: November 23, 2005, 06:27:29 PM »
the front third member will fit into the front and rear housing of a samauri, but, only the front(so you have to find 2 fronts)and you have to tear the one you put into the rear apart and put the samuri side gears in to the kick third. i beleive the spline count is different. there are also 2 different gear ratios (actually more , but these two are the most common)4.63 to 1 , and 5.12 to 1 . the 5.12s are in stickshifts and the 4.63s are in automatics. there are other ratios like 4.88 and 5.89 but they were only produced for special years and  i'm not sure on years.
hope that helps
jason
Offline mlovetripp0
  • 204
  • do more with less
Re: got a ?
« Reply #2 on: November 23, 2005, 06:34:50 PM »
thnx. i found a 96 sidekick in the salvage yard and its standard. the tech sheet on my trcker says that it had the gears .hopeing i got lucky for my zuki
87 sammi
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: got a ?
« Reply #3 on: November 23, 2005, 07:56:36 PM »
hope that helps
jason
Several vendors sell "cans" that fit around the spider gears on a tracKick to keep them in place.  ($30.00 American) Just a matter of mounting the tracKick front R&P in the sammy carrier.
The rear R&P is much larger.  The only way to re-use it is to buy/build a hybrid Samurai/TracKick rear axle.  The other solution is to latch onto a second 5.12 front R&P and install it with a kit in the rear.
Do a search at the site in my sig, below,  for "third" and find all kinds of juicy info on this topic!
Ack
