8V ECU will it work with same year 16v?
  • 2129 Views
Offline rkteckt
  • 214
« on: November 24, 2005, 12:09:30 PM »
I can get a 94 4dr kick with a bad motor pretty cheap, and i can also get a 16v 94/95 motor pretty cheap.
Am i going to need a 16v ecu fort eh swap to my samurai or will the 8v ecu work?
thanks
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
Offline zaggy
  • 1134
Re: 8V ECU will it work with same year 16v?
« Reply #1 on: November 24, 2005, 12:28:25 PM »
The 8 valve ECU will not work with the 16 valve
Apples to oranges, doesn't have the programing to run the system.
Zag
« Reply #2 on: November 24, 2005, 01:45:37 PM »
The 4 door should be a 16 valve, buy them both and fix the foor door.
Offline rkteckt
  • 214
« Reply #3 on: November 24, 2005, 08:44:28 PM »
The four door is a 2wd and edmunds.com lists that model as a 8v engine.....as far as i can find on the net anyway.
And part of the reason for buying it is to get the ECU and other engine bay materials necc for a samurai swap, so if the ecu is not compatible there isnt much sense in buying it Im afraid.
But thanks for the info guys.
2005 Avalanche Z71
2003 Matrix XRS
« Reply #4 on: November 24, 2005, 09:36:37 PM »
If you can get someone to pop the hood maybe it is a 16 valve that would help right?
