Going to do a 16v swap into an 8v kick.
  • 1818 Views
Offline sidekickin
« on: November 26, 2005, 09:08:50 AM »
Has anyone on here done this? I know I will need to change the wiring harness, the ecu, and some exhaust mods. I have also been told I need to do the fuel pump, is that true? Any advice would be great. Thanks.
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
Re: Going to do a 16v swap into an 8v kick.
« Reply #1 on: November 26, 2005, 11:50:12 AM »
Yep, I have swapped a few 16 V's into older 8 V Track/Kick's.  In a friends 1989 Tracker we switched the complete harness and even upgraded him from the 1989 to the 1995 dashboard and added tilt column at the same time.  For Krusty I modified a 1994 16 V harness and added it to the existing 8 valve wiring harness....piggyback style. Works fine either way, but swapping in a complete harness is the cheapest and cleanest. There are few wiring changes between those years and when there were changes 99.9% of the colors match up. IF you go to swap in a 1996 or later OBD2 16 valve it is a bit more complicated since the dash  and the plugs changed quite a bit and you would be better off modifying the harness then piggybacking the wiring harnesses.
Hope that helps you a bit.
Sean
Offline sidekickin
« Reply #2 on: November 26, 2005, 02:04:57 PM »
I have a complete 1994 2wd donor vehicle. It is going into a 1989 sidekick.
Offline zaggy
  • 1134
« Reply #3 on: November 26, 2005, 02:08:01 PM »
I would put them side by side and swap the whole shotting match, the it's doen and right.
Zag
