1.6L 16V timing question
  • 11 Replies
  • 4875 Views
Offline fallguy
  • 127
« on: November 26, 2005, 01:50:17 PM »
hay guys im building a 1.6L 16V for my sammy and I was putting the timing belt on and on the cam pulley there are two markings one is an I im assuming thats intake the other is E exaust ?  Whitch one should I use I have the crank pulley at the mark shown whitch is straight up with number one at TDC.  Also how do you set the valve lash
 Thanks guys anny help would be great
Re: 1.6L 16V timing question
« Reply #1 on: November 26, 2005, 03:48:02 PM »
I don't know but I do recall a thread a while back with that info in it. Try a search back over the last 6 months.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: November 26, 2005, 07:12:46 PM »
There is an article (or two) on the subject at Acks FAQ  based on that thread.  Click on "View Forums" then do a search for timing.
There is no mention of "I" and "E" though (I don't recall seeing those marks the last time I was doing a timing belt change) --  just the arrow stamped on the cam pulley pointing up.
I CAN tell you that if there is no arrow on the face of the cam pulley (somewhat hard to believe...), the cam pulley should be set so that the intake and exhaust valves on Cylinder #1 are closed indicating an igniition stroke. The exhaust valve should be closing on #4 at this point indicating the top of the exhaust stroke. Some sort of mark on the face of the pulley should be aligning with the notch stamped into the dust cover behind the pulley.
Unfortunately, you'll need to take the valve cover off in order to see all this.
I hope this helps!
Ack
« Reply #3 on: November 26, 2005, 10:48:14 PM »
Mark on the cam should point down
to fire #1, otherwise time mark up to
Cyl #4, otherwise you will be 180* out
on the ignition
« Reply #4 on: November 26, 2005, 11:23:01 PM »
so if he's out he could pull the dist turn the crank one revolution put the dist back in and go with out pulling the belt off.  ;D
Offline fallguy
  • 127
« Reply #5 on: November 27, 2005, 11:27:20 AM »
ya thats great but the problem remains where should i set it to the "I" or  "R" there two diffrent settings when i took it apart but i marked it and the "R" seems to be where it was but i want to be sure dont want to put it in the zuki and find out later i gotta change it to the other setting because the cam positioning is diffrent on the ''I" and the "R" where the cam is and the valves open diffrently i checked it out last night  maby im overlooking the whole thing maby it dosent really matter but i figure that you guys are the experts thats why im asking
    thanks
« Reply #6 on: November 27, 2005, 01:13:17 PM »
From the previous thread:
mrfuelish, There are 2 marks "I" and "E".  "E" being the one that is standard. On closer inspection it looks like it may be slightly retarded.  I was guessing that it had something to do with other markets having better or worse grade fuels.
Offline ack
  • 1659
    • Ack's FAQ
« Reply #7 on: November 27, 2005, 01:18:36 PM »
While I might debate to some extent about whether the cam mark should be pointing up or down (I have had success specifically with a 1.6 16-valve MFI engine -- the one with four injecters -- setting the cam and crank pulleys with the marks pointing up)  I am at a loss about the "E" or "I" marks.  Perhaps you have a 1.6 that is newer than 1995 unit and the markings are different?  If you do have a factory cam pulley (at least 1993 or older), there is an dot or arrow stamped into the face of it.  The "up" and "up" alignment should look like this:
(from Chilton's Total Car Care '93 Sidekick CD available through Ack's FAQ)
Right-click and "save as" the picture to your PC to see more detail.  Pictured is a cast or forged pulley.  Some engines have a stamped steel pulley similar to the older 1.3 engines.
This is the same setup as published in the Chilton Suzuki Samurai/Sidekick Geo Tracker manual and the Haynes manual (which is much more useful as campfire kindling...)
If you have an aftermarket pulley, use the method described in my post (above) to find the Top Dead Center (TDC) position for cylinder 1 on the camshaft which would be equivalant to "dot or arrow up".
Hope this helps!
Ack
« Reply #8 on: November 27, 2005, 08:46:26 PM »
« Last Edit: November 27, 2005, 08:51:31 PM by mrfuelish »
Offline fallguy
  • 127
« Reply #9 on: November 28, 2005, 03:27:37 PM »
the motor came out if a 1992 4 door sidekick 4wd hardtop mulit port fuelinjection but im not sure if this was the original motor in the car or not
Offline ack
  • 1659
    • Ack's FAQ
« Reply #10 on: November 28, 2005, 03:48:44 PM »
Ack
« Reply #11 on: November 28, 2005, 09:33:29 PM »
It worked last night? I guess I might have to host it some place else!
