my new vitara/ tracker
  • 12 Replies
  • 3441 Views
Offline roeman
  • 62
  • 1994 sammy!
« on: November 27, 2005, 04:23:44 AM »
Hi,
i have just got a 1995 vitara in the uk, mainly for road use so i can turn my sammy into a beast!
All seems good,
but i have noticed that the gear lever is loose, it has lots of play and can move up and down, i think it pulled hard enough it might come out!
is this an easy prob to fix?
Cheers Roeman
1994 sammy
1995 Vitara 16v
Offline roeman
  • 62
  • 1994 sammy!
Re: my new vitara/ tracker
« Reply #1 on: November 27, 2005, 05:52:53 AM »
o yeh, its a manual if that helps
1994 sammy
1995 Vitara 16v
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: November 27, 2005, 08:14:37 AM »
When you say up and down I'm assuming you don't mean up and down into the gears.  More like out away from the transmission and down towards the transmission?
That's normal to some extent, every manual transmission that I've had or used has done that a bit.  Now if it's thunking and clunking up and down without any effort I don't think that's quite right...
« Reply #3 on: November 27, 2005, 10:25:42 AM »
The gear lever is held in by a bayonet fitting if one or both of the pins is broken or missing then the lever will be loose
Offline roeman
  • 62
  • 1994 sammy!
« Reply #4 on: November 27, 2005, 01:12:35 PM »
That sounds like the problem how do i get to that to fix it, do i need to take the gearbox out?
1994 sammy
1995 Vitara 16v
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: November 27, 2005, 01:39:16 PM »
Yep, there is a bayonet-style cap that holds the shifter lever in place.  If this cap is missing or damaged, the shifter lever will easily pull upwards out of the transmission itself.
There are also two bolts in the shifter "hole" that act as pivot points for the shifter itself.  If either or both of these bolts are broken, the shifter will exhibit "sloppyness" in moving through the shift pattern -- shifter rotation and difficulty in easily "hitting" a gear shift.   Although a classic failure on the SJ-413 (Samurai) 5-speed transmission, I have never heard of that failure on a Vitara/Tracker/Sidekick manual 5-speed.
I vote for Rhinoman's diagnosis!
Ack
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #6 on: November 27, 2005, 11:45:24 PM »
there is also a plastic collar that sits in there that can easiliy go a miss or break u that will cause slop
Markyb (UK)
UK Vitara JLX SE
Offline roeman
  • 62
  • 1994 sammy!
« Reply #7 on: November 28, 2005, 05:15:57 AM »
I can find the gear fine, its just loose, im pretty sure that it sounds like the bayonet fitting, how do i find it?
1994 sammy
1995 Vitara 16v
mudfkr
« Reply #8 on: November 28, 2005, 10:45:36 AM »
Remove the rubber boots from the inside of your trucklet under the plastic console.
Place gear leaver in neutral position then where the stick goes into the gear box there's a sheet metal piece around the top, push this down with your fingers and rotate it (can't remember which way) it will the pop up allowing you to remove the stick.
You'll then see the Bayonet fitting on the sheet metal part that they are talking about.
HTH
Offline roeman
  • 62
  • 1994 sammy!
« Reply #9 on: November 28, 2005, 12:11:34 PM »
HTH
Cheers mate, i got the afternoon off tommorow, so il try it then
Lets hope it works,
If it is the bayonet pin, can i just ring up my zuki dealer and get a new one?
 ;D
1994 sammy
1995 Vitara 16v
Offline roeman
  • 62
  • 1994 sammy!
« Reply #10 on: November 29, 2005, 08:18:28 AM »
hi!
i think u found out what wrong, underneath the metal bit that you push down, there is a spring, that spring has broken, therefore not putting tension on it, and the gearlever being loose!
I'l ring up my zuki dealer tommorow and see if they can get me the spring! bet its gona be an expensive spring!
1994 sammy
1995 Vitara 16v
« Reply #11 on: November 29, 2005, 09:01:51 AM »
Time for a trip to the breakers, the gear lever only comes as a complete assembly and it isn't cheap.
Offline roeman
  • 62
  • 1994 sammy!
« Reply #12 on: November 30, 2005, 08:34:14 AM »
Got a new assembly for £55 ($90ish) from my zuki dealer,
Problem is now i cant get the old gear knob off the old shfter! it proper stuck, it is just an unscrew right?
Also it look like its gona be tricky to compress the spring and turn the bit on top of it at the same time.  Is it gona be hard?
cheers roeman
1994 sammy
1995 Vitara 16v
