Automatic trans not working
  • 2231 Views
Offline Ddog87
  • 109
« on: November 27, 2005, 07:35:52 PM »
I let my son drive my 93 sidekick and it would not go  :'(  I got home and it seemed to be low on fluid, but no signs of leaking ??? so I filled it up and drove it around for awhile. Seem to be slipping a little so I added more fluid. Then it started to leak at the back of the motor were the trans bolts to. Could this be a front pump seal or ???? Any help would be appriciated Thanks
Re: Automatic trans not working
« Reply #1 on: November 27, 2005, 09:08:14 PM »
That sounds like a trans (pump) seal, or
the seal around the Torque Convertor
Slipping, how often has the fluid been
changed ? and how many miles on it ?
Offline Ddog87
  • 109
« Reply #2 on: November 28, 2005, 09:26:47 AM »
The fluid was pretty much changed when I did the motor rebuild. Is the front seal easy to change?? Pull the trans and replace ?? Thanks
« Reply #3 on: November 28, 2005, 09:55:31 AM »
How, long ago did you rebuild the engine ?
The reason I ask is on reassembly you may
have damaged the seal in the trans.
I replaced mine whenI did the engine too,
looks like a pain to change, until you know
the secret, go get a cheapy dent puller with a
2 LB slide hammer on it, pierce the seal with
the screw (on the end of the puller) and slide
hammer it out, slick and easy.
I got a reaplacement seal from a bearing place,
these seals are a silicone lip type, and I bet $20
from the dealer, I got one for $5 waited 1 day for
it to get there, and picked it up, take the old seal
for # cross reference, best way to get the right one
Offline Ddog87
  • 109
« Reply #4 on: November 28, 2005, 07:13:10 PM »
Rebuilt the motor about a month ago. The rig sat for two years or so , could the seal maybe hsve dried out ???????? ???
« Reply #5 on: November 28, 2005, 07:15:02 PM »
Not if it's silicone, that doesn't dry out
Could it have got friction burned from
no oil on it at startup ???
Offline Ddog87
  • 109
« Reply #6 on: November 28, 2005, 10:39:07 PM »
So is it easier to pull the motor or the trans. I've pulled the motor about 6 times but never a trans
