MPG woes...
  • 2335 Views
Offline maybe2fast
MPG woes...
« on: November 28, 2005, 01:27:14 PM »
well I have been driving the Tracker full time now that I put the Reatta away for the winter. I just think the Tracker isn't getting the optimum MPG. I only seem to get 18-21 mpg
newer plugs wires and cap and rotor
the tires are alittle bigger but should throught the trip off too much so maybe 18-22mpg
when the truck is cold I get some spark knock that can be heard inside the cabin, but as soon as it warms up it runs great.
no check engine lights, I think the Coolant temp sensor is messed up though. (only reads 1/4 gauge warmed up)
only about 180-190 miles per tank.
1990 1.6 8v 5 speed 4x4
Offline LawDog
  • 531
    • Emerling Chevrolet
Re: MPG woes...
« Reply #1 on: November 28, 2005, 01:52:26 PM »
Maybe a restricted exhaust??
Offline karl214
  • 228
Re: MPG woes...
« Reply #2 on: November 28, 2005, 01:58:32 PM »
here's a link to the gas mileage other members are getting...http://www.zukiworld.com/forum/index.php?topic=8044.0
Myself i was getting some where around 22 with a bad head on a 90 tracker.. hope this helps a little.. ;D
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
Offline maybe2fast
Re: MPG woes...
« Reply #3 on: November 28, 2005, 02:05:50 PM »
no restriction there! no cat and a free flowing muffler
3" cone filter and tubing
Re: MPG woes...
« Reply #4 on: November 28, 2005, 02:08:21 PM »
Sounds about right for an 89-90 with an auto trans,
a little low for a 5 speed, but not too bad.
What you think is spark knock is actually piston slap,
and I would suggest you let the trucklet warm up
before getting on it in the cold weather. Also use 5-30
weight motor oil, I would use 0-30 if I could find it in
other than Mobil1, great cold weather starting oil.
You could advance the timing to about 12* advance,
that should help the performance some, but I think you
might be running a worn engine, and your mileage shows
that the engine is working harder and not getting 23-28
like others have got with a 5 speed
Offline maybe2fast
Re: MPG woes...
« Reply #5 on: November 28, 2005, 02:42:17 PM »
the truck runs great! it sure sounds like spark knock!
Offline jzap
  • 515
  • How difficult can it be?
Re: MPG woes...
« Reply #6 on: November 28, 2005, 04:51:18 PM »
what tire pressure are you running?
My MPG drops to the low 20's when TP is set to "factory recommendation".
When I pump up to about 32 psi, I get about 30 MPG (25 to 27 in cold weather).  Rides like a brick, but worth it in my opinion.
'96 1.6 16v 5 spd on 225x15's
Jim Z.
66 Apache camper
Offline maybe2fast
Re: MPG woes...
« Reply #7 on: November 29, 2005, 02:02:20 PM »
I will check the TP...
