Kick t-case seal info needed
  • 1486 Views
Offline cj
  • 1276
  • I drive a really big ATV
« on: November 29, 2005, 03:13:39 AM »
Anybody know the specs for the oil seal on the front of the Sidekick t-case where the front drive shaft enters. I've got a leaking seal that needs replacing but I need a replacement ready before I pull the old one.
Offline mbmarkyb
  • 461
    • UK Vitara
Re: Kick t-case seal info needed
« Reply #1 on: November 29, 2005, 04:30:19 AM »
I would bet you a dollar that its the prop and not the seal.
If you have a good spare prop try it first,   When you get the seal your replace it and with mine it still leaked , I question myself thinking i must have pinched it,  i had a new ta case on the way so thought cool no more leaks ,   and it leaked put a new prop in and wayhey no leak
Markyb (UK)
UK Vitara JLX SE
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: November 29, 2005, 01:22:58 PM »
I've changed both front and rear output seals before with positive results.  I don't think there could be any other problems than that.
1993 4-door Sidekick
4.24:1 t-case
