Lockright lockers
  • 1875 Views
Offline dave
  • 31
Lockright lockers
« on: December 01, 2005, 08:19:43 AM »
Today i've received my lockrights. I've odered 1 for a sam rear and 1 for kick rear. But wenn i compere both gears (="driver's"à tjey look the same and they have the same size. The only diffrence is that the sam kit has pinionshafts in it and the kick kit dont.
Is that normal??? I thought that the kick gears would be bigger?
Offline chet
  • 556
  • Zuki time!
Re: Lockright lockers
« Reply #1 on: December 01, 2005, 08:47:19 AM »
is the kick one for the front or rear? axle shafts are the same size in the rear of a kick and a sammy. the third member and ring gear is bigger and I THINK the carrier is bigger as well.
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #2 on: December 01, 2005, 09:37:25 AM »
I'm told you can actually put the Samurai rear lockright into a Sidekick rear carrier so I'm guessing they will be the same size.  If you read the hybrid rear axle info on Trail Tough's site: "Can also be used with the Samurai type Lock-Right or E-Z Locker. ".  I'll be trying this when I get around to putting my hybrid rear in.
Offline trailtracker
  • 44
  • the fixing/modification is endless!
« Reply #3 on: December 03, 2005, 08:16:34 AM »
from what i understand they dont make a locker for the front of a side kick???? i have just put a rear in and would like a front. after looking at all the writeups on front end strengthening it looks as if i would need a samurai carrier and have it machined to fit cv's?
Unsafe at any speed
  • 44
« Reply #4 on: December 03, 2005, 03:20:18 PM »
ok from i have been studying this front end strengthening/locking and it looks like i would need to buy a samurai carrier, have it machined to fit cv's, and it should fit right in my front end i think. the only question is, is do i have to get a samurai front or rear third? has anyone else done this that i can ask a few more questions? thankks
Unsafe at any speed
