Removing ECM?
  • 2918 Views
0 Members and 12 Guests are viewing this topic.
Offline CRONIC
  • 9
Removing ECM?
« on: December 01, 2005, 06:08:41 PM »
Does anyone know if there are any special procedures before removing the ECM (from sidekick)?
-thanks
Offline zaggy
  • 1134
Re: Removing ECM?
« Reply #1 on: December 01, 2005, 06:46:25 PM »
Disconnect the battery
Zag
Offline CRONIC
  • 9
Re: Removing ECM?
« Reply #2 on: December 01, 2005, 10:02:01 PM »
sorry to be a pain but ......thank you........but...............
Need Help !!!  ??? :-\\\\
I tried removing the ECM but theres screws everywhere and the ones i tried removing were being eaten by the screwdriver..........how many should be removed?
I heard from several people that the ecm can be removed from the compartment right under the stearing wheel, but i clearly see the ecm in the compartment to the left of 'that' compartment and behind the small horn (yellow circle in pic)........?!?
P.s.   i also attached a picture for better understanding.
thanks for all the help...............just click on picture for better view.
Re: Removing ECM?
« Reply #3 on: December 01, 2005, 10:42:48 PM »
ya thats where it's at, there is also a couple of small black relays hooked to it, those screws are tight, real tight,Ihad to use a tee handle type phillips on mine,if there is a medium size black box there leave it alone, the one you want is tin looking.
Offline CRONIC
  • 9
Re: Removing ECM?
« Reply #4 on: December 01, 2005, 10:49:00 PM »
but when you say those are it ........do you mean the screws that i cirlced in 'green'.....or the ones behind the speaker in the compartment........thanks.
Re: Removing ECM?
« Reply #5 on: December 01, 2005, 10:59:47 PM »
you can pull the speaker out to see it a little better, but the screws you want are probably going to be reached from underneath by the pedles, I stripped one of them and had to take the whole bracket of holding the relays and everything, hope that helps. get a philips bit that fits the screws real good and put it on a rachect with an extension and push on it all your worth while trying to turn it.
Offline CRONIC
  • 9
Re: Removing ECM?
« Reply #6 on: December 01, 2005, 11:01:05 PM »
I'll try again in the morning ...thanks plenty :)
« Last Edit: December 01, 2005, 11:05:29 PM by CRONIC »
Offline cj
  • 1276
  • I drive a really big ATV
Re: Removing ECM?
« Reply #7 on: December 02, 2005, 12:36:19 AM »
When I swap them out, I pull the speaker to give easy access. I only undo the speaker screws and the ECM screws, never needed to undo anything else. Only takes a couple of minutes.
Re: Removing ECM?
« Reply #8 on: December 02, 2005, 09:26:33 AM »
You got to stick your head down next to the
clutch pedal and look up, it's up there, the speaker
will make seeing it easier, but i don't think you
can see the screws better than from under the dash
Steel box with a clear plastic thing over it to keep
dust and water off I guess, my plastic broke, it's
like a piece of blister pack plastic, not thick at all
Looks like a PITA, it's not that bad
« Last Edit: December 02, 2005, 09:28:19 AM by wildgoody »
