E-brakes
  • 10 Replies
  • 3390 Views
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
E-brakes
« on: December 09, 2005, 02:08:22 PM »
is a line-lock as good as a manuel e-brake. lookin for some opinions??   stan
Offline ROSS
  • 1412
Re: E-brakes
« Reply #1 on: December 09, 2005, 02:34:13 PM »
works good stan. we put one on freds sammi after strechin it.
Ross
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: E-brakes
« Reply #2 on: December 10, 2005, 06:44:13 AM »
They work pretty good in offroad applications.  Apply the brakes, engage the line lock by pushing a switch or button, release the brake. You don't move.  They are very helpful in holding a position on an obstacle while shifting and clutching to select a better gear ratio and working the throttle.
However, in an on-road driving emergency where the truck is in motion or you have lost use of the hydraulic brakes, line locks are worse than useless.
Offroad use only.
Ack
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: E-brakes
« Reply #3 on: December 10, 2005, 09:04:11 AM »
a couple of the tow trucks we service at my shop use the line lock for the e brakes. up here e brake cables dont last too long before they stop working so this is a much more reliable system.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline 37kicker
  • 319
Re: E-brakes
« Reply #4 on: December 10, 2005, 09:53:19 PM »
what  i'm tryin to find is another option to disk/drum-rear brake. saturn are disk/disk. but are big  $$  new  thats what we' ve been using . is there any other disk/ disk rear brake that is less $$ than saturn brakes i like the manuel e-brake on the saturn. but line-locks are easy to install. the j-yard is running out of saturn stuff!   stan
Re: E-brakes
« Reply #5 on: December 10, 2005, 10:22:30 PM »
Try Maxima rear calipers, tons of them at the
wreckers, I found them looking for Saturn ones,
never did find any Saturn rear disk/calipers.
Offline 37kicker
  • 319
Re: E-brakes
« Reply #6 on: December 11, 2005, 03:43:24 PM »
i'll check it out  :) thanks   stan
Offline ack
  • 1659
    • Ack's FAQ
Re: E-brakes
« Reply #7 on: December 11, 2005, 04:54:39 PM »
derek
Just to clarify here so some goof reading this ends up doing something stupid:
There is a difference between Emergency Brake (eg. E-brake) and Parking Brakes.
A Parking brake is used to keep a stopped (parked?) vehicle from moving.  A line-lock Parking brake would be excellent for a tow truck -- especially when the truck is pulling a vehicle out of a ditch.  Over time a mechanical, cable-driven emergency brake would suffer from water damage and become unreliable.  A line-Lock Parking brake would not be prone to a slow failure and would work as good as the braking system itself.  And, it could be set up to lock up all four wheels.
Heck, a line-lock parking brake on the Electronic News Gathering (ENG) vans at work  woul;d benefit from line lock parking brakes.  If wired properly, it would be danged hard to move a truck while the transmitting mast is raised and the line locks were engaged.
An Emergency brake conjurs up the idea of plummeting down a steep grade trying to stop a vehicle with bad hydraulic brakes.  You grab on the handle, pull and pray.  Line locks would be pretty useless at this point as emergency brakes.
Ack
Re: E-brakes
« Reply #8 on: December 11, 2005, 05:04:51 PM »
For what it's worth, your Emergency brake
is pretty worthless at that point too, might
be why they are called Parking Brakes now.
You would have to be in a real emergency
to even think about using it for a failed brake system.
Offline ZeusZuki
  • 411
Re: E-brakes
« Reply #9 on: December 11, 2005, 10:38:24 PM »
Hi Stan,
I am pretty sure Wildgoody and I had a thread on this a while back - Toyota MR2 or front 80-82 disk brake calipers have a screw type actuator - I used the MR2 set up on ZeusZuki and it pulls up with 37 wranglers pretty good.
Good luck ;)
ZeusZuki.
Offline 1bigtracker
  • 3409
Re: E-brakes
« Reply #10 on: December 12, 2005, 12:24:00 PM »
  ÂÂÂÂÂÂÂ
