Installaed new bumper - now it wont start?!?!?! Help!
  • 9 Replies
  • 2722 Views
Offline ShawnQ
  • 64
  • Cruising the Beaches of South Texas!
    • Lone Star Sharkers
« on: December 10, 2005, 05:47:28 PM »
Ok guys, I'm sure you've seen the bumper thread...
Now that I installed the new bumper, I went to back it up, and the sammy fired, then died. No problem, hadn't been run in a few days...right?
Well, I tried to crank it again, and it just cranks and cranks and cranks...wont fire! Now I feel like a real idiot!
I didn't change ANYTHING else.
I am smelling fuel, so it's not a fuel problem.
What's the best way to check spark on these?
Timing and compression are fine, it ran perfect 2 days ago.
The only thing I did was disconnect the battery when hooking up the new lights.
Any ideas?
Thanks
Shawn
'88 Samurai - SPOA Lift, Stock 1.3L, 235/75-R15's
'04 Dodge Ram 2500 Cummins - 4wd, 2" leveling kit, Off Road Package
Offline 94track
  • 212
Re: Installaed new bumper - now it wont start?!?!?! Help!
« Reply #1 on: December 10, 2005, 05:58:41 PM »
pull # 1 plug and put plug wire back on it, lay the bottom of the plug on a ground(exhaust manni) and have someone crank it over, you should see spark.  Also was this the first start up after the lights were installed
Offline ShawnQ
  • 64
« Reply #2 on: December 10, 2005, 06:04:31 PM »
This was the first start after the lights, why is that?
They are tied into the factory harness, same number of wires, nothing fancy.
Thanks
Shawn
Offline ShawnQ
  • 64
« Reply #3 on: December 11, 2005, 12:11:14 PM »
Figured it out.
Turns out the choke was sticking on the carbureator. Turned it over and had my uncle push the choke open with a screwdriver and it fired right up...runs good again.
Weird  ???
Any idea how to prevent that? I'm 'Carb Stupid'...I can handle EFI, but don't know anything about carbs (I'm a young guy, grew up EFI).
SQ
Offline camozuki
  • I luv to explore the desert
« Reply #4 on: December 11, 2005, 12:55:08 PM »
Sounds like you should buy uncle lunch and keep him close. LOL !
Exploring the desert near Las Vegas
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: December 11, 2005, 06:21:44 PM »
Way back when cars had carburetors, it was often necessary to stick a pencil down the carb to hold the choke open to get the engine started.  This was especially common on Ramblers and Fords that used the Carter YF single barrel carb.  The nice thing was it was easy because the air cleaner was held on by one wing nut and didn't have a bunch of hoses and junk attached to it...
We never did come up with a fix for it, we just made sure to keep a pencil in the glove box.  It was a part of life back then.  Even my wife learned how to do it.  This was her car...
« Last Edit: December 11, 2005, 06:25:37 PM by jzap »
Jim Z.
66 Apache camper
Offline samuraiVT
  • 89
« Reply #6 on: December 11, 2005, 07:04:33 PM »
thats really weird that happend because about a week ago i parked my sami outside over night the next morning i went to fire it up and it did exactly what you described but i kept cranking it until it fired and i let it idle and warm up then i went to move it and as soon as i would give it a little gas and take my foot off the clutch it would slowely bog donw and quit i dont know whats wrong with it i just thought that was weird
88.5 samurai 8in springover lift 32x12x15 firestone RMT's on black rockcrawlers lockers front and rear with auto tracker seats sidekick gears custom bumpers front and rear spray in bed liner soon to come winch, paint, top,  hopefully a 1.6l swap full roll cage and some other
Offline ShawnQ
  • 64
« Reply #7 on: December 11, 2005, 08:16:58 PM »
Check the choke plate/flap on the carb...easy fix now that I know what the problem was!
jzap, cool story and cool car! My uncle is only 37, so he probably wasn't around in those days. He did however race in a 4cyl division at the local circle track for about 15yrs, and all of the engines used holley 5200's and webers...so I assume it has happened before.
I was thinking it may have to do with that 'wax-ball' I've read about...
SQ
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
« Reply #8 on: December 12, 2005, 11:43:12 AM »
WAX BALL???
Offline ShawnQ
  • 64
« Reply #9 on: December 12, 2005, 12:06:09 PM »
Do a search for 'Wax Pellet'....
