Orange rig is getting a makover!
  • 233 Replies
  • 59536 Views
0 Members and 53 Guests are viewing this topic.
Offline echojeff
  • 414
  • Lo que sea
Re: Orange rig is getting a makover!
« Reply #135 on: March 01, 2006, 09:26:50 PM »
some kind of strut brace?
95 Kick 4dr JLX.
Offline hobgoblin
  • 224
« Reply #136 on: March 01, 2006, 09:40:19 PM »
Hello,
I take a guess...Is it a carrier bearing support???
Later Tom K.
« Reply #137 on: March 01, 2006, 10:03:29 PM »
Not real sure what that even is.  Kind of a solid axle guy that doesn't ask questions.
'86 MJ, 2.5 AMC, 904, NP207
'85 GMC HD2500, 350, 33s
'84 Toy, 20R, fenders cut like an emo kid
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #138 on: March 01, 2006, 10:15:32 PM »
I think he said he was using stock sidekick knuckles...
The more I look at it the smaller I think it is than it looks - I'm thinking a steering brace for the idler arm, or steering box ......
« Last Edit: March 01, 2006, 10:17:54 PM by Uncivilized »
Offline b1pig
  • 61
    • Jeep
« Reply #139 on: March 01, 2006, 10:30:24 PM »
I think he's right. I looked at the thing real hard for about the past hour. I havent been following the article. (been off the forum a while). Using a OEM knuckes... the mounting plate has about the right spacing...  That is the best idea that I can come up with myself since it is "front suspension related. On a custom rig, this is a hard guess. The only thing that I can think of that a person would want bolt on is differential mounts and the mounting points for suspension components. All mounts would be welded, not bolt on. That one suspension peice is all I can consider.
...but who knows... the front end of the rig doesn't appear to be the only thing he has that's bent. ;)
b1pig
'90 Tracker, '07 JK Rubi
Offline Maroon Monsoon
  • 876
« Reply #140 on: March 01, 2006, 11:31:51 PM »
I don't know if it's been said, but is it a front diff mount?
Offline rockrat
  • 196
  • Got Ringr
« Reply #141 on: March 01, 2006, 11:36:36 PM »
Finally the first SPY cam photo of the Orange Rig and it's make over  :o
OK , it's only a part off of it. BUT:
If you are the first Zukiworld member to properly identify this part, wewill send you a free Zukiworld decal  8) So let's see who knows their stuff.
Lower control arm for use with a spherical ball mount large hole, 2 holes are to locate the spring?
Offline ZeusZuki
  • 411
  • I like em low with big feet. New Zealand.
« Reply #142 on: March 02, 2006, 12:34:31 AM »
Yea ha, I have it ;D
It is a front suspension component fabricated from mild steel ::)
So where is my Patch ??? C'mon guys ;)
ZeusZuki 8)
1600 Escudo / Kick, beam front, coils all round, 37 MTR's, 97" wheelbase, locked fr & rr,twin stick, front stock ratio, Calmini 5.14 t box rear, Warn XD9000i winch, blah blah!
2.0 V6 auto, Calmini 3" kit, 33" jandles, LT struts, blah blah
2.5 V6 man GV, Calmini 2.5" kit, 235/85x16 jandle
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #143 on: March 02, 2006, 03:32:36 AM »
front bearing support........ for the weak side front axle
Online ebewley
  • 6603
  • 69
« Reply #144 on: March 02, 2006, 07:16:01 AM »
Guys,
If you want your guess to count, go to the other post!
Thanks, Eric
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #145 on: March 02, 2006, 05:29:07 PM »
ok I know this is a far one but can you do a suspension or adapt the design from the H1 to give clearance and keep the drive shafts in line i do not know of another vehicle that uses this but or a 2 piece shaft to break up the extreme angles...does this make sense.....
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
« Reply #146 on: March 02, 2006, 11:42:52 PM »
Yep, i thought about that for the CVs, but there
just isn't room under the trucklet for all that extra stuff
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #147 on: March 19, 2006, 01:28:26 AM »
INSIDE  INFO,    THE ORANGE RIG IS GETTING IT'S FIRST BEATING SUNDAY  3-19-06   THATS ALL I KNOW ............ BUT IT LEFT THE SHOP IN 1 PIECE.  SEE HOW IT RETURNS ,,,....IF IT DOES!!   STAN
Offline brlj
  • 512
  • 6" Lift w/ 33x12.50 TSL Radials, Exoskeleton
    • Bills 93 Tracker
« Reply #148 on: March 19, 2006, 06:56:54 AM »
Wheres the pics????????????
Offline hobgoblin
  • 224
« Reply #149 on: March 19, 2006, 07:11:51 PM »
We want PICS!!!!!!PLEASE ;D ;D ;D ;D ;D ;D
