Project kimera Buildup
  • 24 Replies
  • 5819 Views
0 Members and 16 Guests are viewing this topic.
Offline rockrat
  • 196
  • Got Ringr
« on: December 15, 2005, 10:12:57 PM »
Body side of hinge, You cant see in the pic but it is radius'd to fit the 1.5" tube that is bolted to it. It also need the pins pressed into it.
Door side of hinge
More work to the front Exo
Offline rockrat
  • 196
  • Got Ringr
Re: Project kimera Buildup
« Reply #1 on: December 15, 2005, 10:13:29 PM »
Well the rig leaves tomorrow night for Rhino liner then goes to paint on wed, so it has been 2 days worth of PUSH... here are some updates.. Next pics will be with color...
Fixed all the major holes in the bed cut out old rust and welded in new metal (YUCK)
Tube bung with flush mount allen head (holds rear tube to floor)
Vertical bars to hold aluminum plates( view through to cockpit counsel)
Above pic,,, the angled tubes are cut then sleeved, then they bolt through the under dash bar, so the cage can be removed.
Aluminum sheet will fill the void with 1 slit for the gear shift Lever (auto trans) also will hold Cigerette recepticales, Mill light and GPS
Offline rockrat
  • 196
  • Got Ringr
« Reply #2 on: December 15, 2005, 10:14:06 PM »
Starting to put the aluminum panels...
And I think I am getting the hang of TIG welding
Offline rockrat
  • 196
  • Got Ringr
« Reply #3 on: December 15, 2005, 10:14:47 PM »
A little more.
Center councel finished, we will have to wait for the tube to come back to mount the forward plate in correctly. Plates all cut for the rear tire carrier, just need to weld tabs in it. Started the cage gussets pics of those tomorrow.
Offline rockrat
  • 196
  • Got Ringr
« Reply #4 on: December 15, 2005, 10:15:59 PM »
Ok, I stoped tonight its all Black, tomorrow the airbrush guy gets his hands on it for graphics and LOGO
More graphics done...
new filler neck
Offline rockrat
  • 196
  • Got Ringr
« Reply #5 on: December 15, 2005, 10:16:36 PM »
Frame tore down and shot with rubber under coat then color.
you can see the path of the new fuel lines, drilled and tapped the frame to hold the billet line clamps
new head light bezel's
I am holding the lite its not crooked..
Offline rockrat
  • 196
  • Got Ringr
« Reply #6 on: December 15, 2005, 10:17:16 PM »
Starting to go back together.. Sorry for the crap pics the digi has about had it.
Starting to finish up the doors, need to finish aluminum panels latches and add a little more tube
Offline rockrat
  • 196
  • Got Ringr
« Reply #7 on: December 15, 2005, 10:17:52 PM »
Start of the rear Exo.. Bob bent it up today and made the bungs and I tig'd it all together and installed them tonight...
Yes that is styrofoam, I didnt want to scratch it.. yes i am anal
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #8 on: December 16, 2005, 12:07:28 AM »
Woaaaahhhh  :o is all I can say right now. More More More pics  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Proud2BCDN
« Reply #9 on: December 16, 2005, 11:11:31 AM »
^^^^^ What he said^^^^^
Incredible work  :o
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #10 on: December 17, 2005, 03:16:36 AM »
LOL! That is about 8 months of work. Yes Scott........... you have had it 8 months now!!!!!! :P :P
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline rockrat
  • 196
  • Got Ringr
« Reply #11 on: December 17, 2005, 07:56:11 AM »
Yep you are right but perfection can not be rushed  ;D
Offline rockrat
  • 196
  • Got Ringr
« Reply #12 on: December 18, 2005, 07:51:31 AM »
Bobs working on the rear I have been finishing up doors... still need to do aluminum panels and door latch.. Hopefully we will finish today so all the tube can go to powdercoat..
Offline jagular7
  • 1026
  • Jagular7
« Reply #13 on: December 19, 2005, 09:29:27 AM »
Is it possible to get a weight idea to the tubing added? Or a final weight at completion? To compare to a Sami, stock and mod'd (the normal way LOL)....
Lenexa, KS
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #14 on: December 19, 2005, 10:21:54 AM »
That looks like a pretty sweet build. I'm facinated by the front end.
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
