Samurai Axle Conversion. . .
  • 2105 Views
Offline Erickson00
  • 24
« on: December 16, 2005, 03:33:05 PM »
Hey i have a 88 samurai and it currently has a 4 inch left and 31s locked front n rear and i am not going to be doing some extensive modifications such as a new 8 inch coil over lift from rocky road and then i am going to be putting a v8 or a v6 (chevy) in it and i am going to need some help on changing the axles. . . . i want something that can take the abuse of the trail, im currently just a trail rider but i am going to get into some rockcrawling. So what would be the best and easiest axle conversion to do on this? Thanks for your help!
BRAD
Offline rockrat
  • 196
  • Got Ringr
Re: Samurai Axle Conversion. . .
« Reply #1 on: December 16, 2005, 06:59:31 PM »
the 2 most commome axle swaps are either Waggy 44 or Toy.. Large debate on which is stronger but they bith do the job. waggys can be done by either outboarding springs or some have ground down the cast to set the axle perch. Toys are alittle more direct move the rear purches in 1" each side and open up the center hole in the stock 3/8" to the inside for the front. Check out www.azrockcrawler.com for a real good writeup on the swap and parts list. Seeing how you are going to do the RRO coil kit get the one for toy axle and you are set.
Offline Erickson00
  • 24
« Reply #2 on: December 17, 2005, 02:42:50 PM »
thanks! is there a company that makes axles just for a samurai?? and then also has anyone used this RRO coil system? I am very interested in it and have heard good things some people have even said its the best? Any thoughts . . .  thanks!
I think i am going to use toyota axles but i would like to buy a whole rebuilt axles already done at least completly fitted for a samurai anyone know of any sites? or who would make one? thanks again
Offline sj416 nz
  • 38
« Reply #3 on: December 18, 2005, 01:19:20 AM »
i am doind the RRO coil lift  it is leving RRO this week same time
will be useing toy axls with 4.88
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
airtec snorkel RRO coil kit toyota running gear 4.88
Offline Erickson00
  • 24
« Reply #5 on: December 18, 2005, 06:55:53 AM »
thanks where did u get ur toy axles thanks brad and what one are u using
BRAD
