kicker 3 in a sammy
  • 1722 Views
Offline mesjr2004
  • 422
kicker 3 in a sammy
« on: December 18, 2005, 01:56:07 PM »
 ok. my buddy is installing a kicker 3 in his sammy . seems its not fitting so good. the transfer case is not located in the same spot , it needs to be clocked down a few degres so he can use the tcase mount he has. he has the mighty kong and it wont match anything anymore , has anyone done this conversion and had the same problem? hs pretty pised about it .
Re: kicker 3 in a sammy
« Reply #1 on: December 18, 2005, 10:27:49 PM »
If you can't get it let me know(p.m. me)I have a friend that put one in today in his sammie, maybe you could loosen up the bolts on the adapter tube and clock it just a little bit, or use the bolt and poly trick on the kong and mix and match the poly's to get it to fit?( loose the stock rubber mounts x3) I have a kong on mine and I mix them two poly and one stock mount.
Offline zooky
  • 135
« Reply #2 on: December 23, 2005, 04:02:37 PM »
I modified the Kong arms:
