headlight bulb out
  • 1876 Views
Offline synergy_58
  • 59
headlight bulb out
« on: December 20, 2005, 07:53:11 AM »
Sorry for this one, but...on a '97 tracker, does the entire headlight have to be replaced when it's burned out or just the bulb?
If it's the entire headlight, where can I get one without having to sign the title over to the parts store?
Thanks!
Offline hcgalvin
  • 1695
    • Granite Path
Re: headlight bulb out
« Reply #1 on: December 20, 2005, 08:14:23 AM »
It's just the bulb.
And the SilverStars might make a great xmas present. ;)
(I've got them in mine and they rock).
Heather Galvin
Offline synergy_58
  • 59
« Reply #2 on: December 20, 2005, 08:39:42 AM »
Great,  that should save me a bunch of money!
Thanks!
Offline toolman21
  • 229
« Reply #3 on: December 20, 2005, 01:51:06 PM »
I would replace both of them, if one went, the other is probably close and dimmer than it was anyway.  The Silverstars impressed me, it was around 35 bucks for two bulbs at the parts store.
Toolman
Offline jzap
  • 515
  • How difficult can it be?
« Reply #4 on: December 20, 2005, 04:06:21 PM »
Pop the hood,
twist the little black retainer ring,
pull the socket and bulb out,
unplug the bulb,
plug new bulb into the socket on the wiring harness,
stick it in the housing,
twist the retainer ring back on...
close the hood.
Takes about a minute...   ...no tools required...
« Last Edit: December 20, 2005, 04:08:17 PM by jzap »
Jim Z.
66 Apache camper
Offline da_tub
  • 307
« Reply #5 on: December 20, 2005, 10:55:44 PM »
and don't touch the bulb with your fingers... the oil on your skin causes the bulb to get a hot spot. and then your back to square one.....
91 four door ,and some stuff
Shilly
« Reply #6 on: December 21, 2005, 06:43:52 PM »
...and did we mention the Silverstars??   ;D
Offline Toy Box
  • 222
  • 00 Grand Vitara
« Reply #7 on: December 21, 2005, 07:58:41 PM »
 Siliverstars are great I have them in my sam.
You Play you Pay
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« Reply #8 on: December 21, 2005, 08:20:02 PM »
Love those Silver Stars!  Funny how everyone has them and no one talks about them!
Super bright without that phony blue look!  Put mine on high in the woods at night and light up the world!
Oh and make sure you put them in right.  You can put them in upside down if you try hard enough and then your lights will look weird when you turn them on.  Just push them in the hole gently and twist the ring until it locks.  If it seems real hard then it may be upside down.
