t case stuck in low
  • 2313 Views
Offline mlovetripp0
  • 204
  • do more with less
t case stuck in low
« on: December 23, 2005, 09:47:29 PM »
went 4 wheeling today and there was small hill, 4 time to get up but failed, last time up my sammy stalled out and i coasted down to the bottom of the hill.got the sammy restarted and attempted to pull forward and it was like i was in neutral.tried to shift the t case into low but the stick wont move,its like its lock in one position.so i got pulled to a clearing and pulled the front of the t case off (the part with the shifter) and i slipped into gear ,so i put the front back on and got in the sammy and the shifter is still frozen in one place but now im in low 4 . ive never taken the t case apart before.will i find something broken or just out of place ?or is there a trick to getting the shifter loose with out a tear down?
« Last Edit: December 23, 2005, 11:34:17 PM by mlovetripp0 »
87 sammi
Offline ShawnQ
  • 64
  • Cruising the Beaches of South Texas!
    • Lone Star Sharkers
Re: t case stuck in low
« Reply #1 on: December 24, 2005, 12:40:01 PM »
Do a search for 'Shifter Sheet'...it is most likely your problem.
To get it out of gear, pull your shifter off the T-Case from inside the truck, and there will be two rods that the shifter slides into. These two rods should make a 'square' that the shifter sits in. If this square is out of line, it wont shift. Line those two rods up with a screwdriver and it will work. Then, buy a new shifter sheet ($8-16), and install it.
You'll be Good to go.
This is an extremely common problem, and I wrote an extremely vague 'how-to'. Do a search, and there are pictorials on how to fix it. It is easy, takes 5-10mins total.
SQ
'88 Samurai - SPOA Lift, Stock 1.3L, 235/75-R15's
'04 Dodge Ram 2500 Cummins - 4wd, 2" leveling kit, Off Road Package
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: December 24, 2005, 01:16:18 PM »
Do a search for shifter and sheet at Ack's FAQ (the URL is in my Signature, below) for a link to an article describing the fix.
Some of us got a great deal on a Samurai because of this common problem... ;D
Ack
Offline takai
  • 907
« Reply #3 on: December 26, 2005, 05:25:44 PM »
Had my sammi do the same thing about 1 week after I got it. Felt really silly when after towing it home, and taking 5 mins to fix something I could have fixed and continued to wheel.  ;D
'Cause, I am to misbehave.
Offline mlovetripp0
  • 204
  • do more with less
« Reply #4 on: December 26, 2005, 05:26:42 PM »
this plastic sheet ,is this some thing that is going to break often?
87 sammi
Offline takai
  • 907
« Reply #5 on: December 26, 2005, 05:37:51 PM »
Not really. Mine was replaced when we put in 4.1 gears, my friends 87 still has the original sheet. And it works flawlessly.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #6 on: December 31, 2005, 07:25:45 PM »
I know this is late but here is a link to an article I wrote.
http://bbs.zuwharrie.com/content/topic,1425.0.html
« Last Edit: December 31, 2005, 07:32:09 PM by nc_zuk »
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
