Where to use a highlift jack on a stock 4dr?
  • 18 Replies
  • 6507 Views
Offline echojeff
  • 414
  • Lo que sea
« on: December 27, 2005, 09:28:02 PM »
I got a highlift jack(actually a Jackall) for christmas.  It looks the bumper covers will have to come off or else damage would happen.  Also, the stock bottom sides look too weak to be jacked there.  Looks like sliders are needed to to jack the thing up.  any suggestions?
Jeff
Ps  is there a good place to mount it?
« Last Edit: December 27, 2005, 09:52:46 PM by echojeff »
95 Kick 4dr JLX.
Offline Dihnekis
  • 398
Re: Where to use a highlift jack on a stock 4dr?
« Reply #1 on: December 27, 2005, 09:54:50 PM »
I dont have experience with this, but I think you should invest in some sliders.
1) Won't damage your zuk
2) With a hi lift it is a good idea to only lift up one front wheel and one rear wheel at a time, not the whole front end or whole rear end.
Otherwise get a hitch for your rear bumper and jack it off that.
1988 Suzuki Samurai
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: December 28, 2005, 05:26:21 AM »
You could also remove the front bumper cover, and just use the re-bar, you could jack from that.
Offline Shredder
  • 389
    • Me & My Rig
« Reply #3 on: December 28, 2005, 06:48:42 AM »
HiLift makes a couple add-ons that will let you lift it. One hooks to a wheel and another one wraps down below the soft bumper.
http://www.hi-lift.com
Works great unless you want to change a tire. Then you will need to put something under the axle to hold it up. They also make this "Bumper Lift" thing. It reaches under the bumper cover and can hook on the frame in some places. I place a leather glove between the bumper cover and the jack to protect the finish.
If you don't have a winch, you do now. Get some shackles and a chain and you can use it with your tow strap to get you unstuck in alot of situations. Saved my |removethispart|@$$ a few times.
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: December 28, 2005, 08:08:35 AM »
with no sliders and the bumper covers on there is nowhere on the body you can use a high lift. DO NOT lift on the rockers! You will crush them!  :o
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #5 on: December 28, 2005, 10:21:39 PM »
How about the recovery loops... that would give you a 50% chance of getting the corner you need up.... :-\
Offline keith
  • 1176
« Reply #6 on: December 29, 2005, 10:52:01 PM »
In the picture what did you attach the top of the jack to and how did it attach?  Also how did you attach the strap to the jack?
Offline Shredder
  • 389
    • Me & My Rig
« Reply #7 on: December 30, 2005, 07:56:30 AM »
I carry a chain with me and a couple shackles. I put a shackle in the end of the jack bar and run a chain through it. The other end of the chain goes to a tree (with tree strap). The tow strap goes between the truck and the jack arm. Take up the slack with the chain and start jacking. It moves it about 2.5 to 3' and then you have to reset it.
It only takes a few minutes to set up and pull. Usually a 3' pull gets you out of the stuck part. Once though I broke through the ice in the middle of a "trail pond"(big puddle). I had to drag the rig about 20' before I was back on top of the ice. Slower than a winch but like i said it has saved my |removethispart|@$$ more than once.
Offline keith
  • 1176
« Reply #8 on: December 31, 2005, 10:24:21 PM »
Do you use a stretch strap or a regular fixed length one?  My longer strap is a strechable one so I wonder if I can use it or not.
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
« Reply #9 on: January 01, 2006, 09:03:38 AM »
Using the high lift like that is a cool idea, but isnt a come-a-long a bit easier to use with a tracker? I get between 6-8 ft pulls with my 2 ton and unless the tracker is buried to the windows it pulls easily. I'll have to show this to a friend who just got a high lift for xmas from his wife to go on their heep.  ;D
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: January 01, 2006, 09:23:32 AM »
The come-a-long would be easier to use for pulling but it can't be used as a jack.
That said I own three 4x4's and there isn't a single place I can use a High-Lift on any of them so I don't own one.  I just always wheel with a buddy and have my straps and other recovery gear with me.
No offense to anyone but it seems like the only times I've seen pictures of or heard of people using High-Lifts for jacks has been when they were wheeling alone and got stuck.  Been there, done that, won't do it again.
Offline Shredder
  • 389
    • Me & My Rig
« Reply #11 on: January 01, 2006, 03:20:14 PM »
I use one of the ProComp straps. They are pretty heavy duty. It has a little stretch to it when winching. I use the chain to draw everything tight before I start pulling with the jack that way I have the most pull per hook-up.
When you wheel alone, like on a hunting trip, it is a usefull tool to have. The last time I had to use it I was in the bottom of a ravine with my Tracker. If another 4x4 tried to get to me to strap me out they would have just been stuck too. The HiLift let me get my Tracker in a position where I could finally get out.
Offline robert_h
  • 30
  • 1.6 liters of fire-breathing power
« Reply #12 on: January 02, 2006, 03:03:47 PM »
I use the Hi-Lift "lift mate" accessory (Shredder posted a photo of it) which uses padded hooks to grab onto the holes in your wheels. It works great. Yes, it'd be better to have someone else along to strap you out, but that's not always possible. The Hi-Lift jack is a great tool, and it's cheap insurance.
Offline echojeff
  • 414
  • Lo que sea
« Reply #13 on: January 03, 2006, 07:49:46 PM »
A friend gave me a set ot these....
If I put U-bolts on them, can I attach them to the stock rack on my 4dr.  Is it stout enough to hold the jack?
« Last Edit: January 03, 2006, 07:51:56 PM by echojeff »
95 Kick 4dr JLX.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #14 on: January 03, 2006, 07:52:58 PM »
I admittedly have never pulled or pushed on a luggage rack on a Sidekick/Tracker but if they're solidly on there and rated enough to actually carry luggage or whatever they should be able to take the weight of a HighLift without any trouble.  Their capacity should be in the owner's manual.
