4x4 4x2 4 wheel drive and all wheel drive what are the differences?
  • 3272 Views
Offline 5282jt
  • 9
Thanks
Offline Shredder
  • 389
    • Me & My Rig
Re: 4x4 4x2 4 wheel drive and all wheel drive what are the differences?
« Reply #1 on: December 28, 2005, 07:11:27 AM »
In a nutshell: Four wheel drive or 4WD, 4x4, all wheel drive or AWD are terms used to describe a four-wheeled vehicle with a drivetrain that allows all four wheels to receive power from the engine simultaneously. However there are full time systems and part time systems for both.
Most AWD cars send power to all 4 wheels with little if any user decision on the matter.
Most 4wd or 4x4 systems allow the user to select between 2wd (2 wheel drive) for less wear and tear and economical opperation and 4wd for traction reasons.
A two wheel drive, 2wd or 4x2 is just that, a car that only feeds power to the front axle or the rear axle, not both.
Trackers and Sidekicks come in either a 2wd (4x2) or a part time 4x4 set up.
Like I said it is a simplified explaination but I hope it helps.
Offline SNAFU
  • 40
« Reply #2 on: December 28, 2005, 07:48:00 AM »
Just to add to what Shredder already said, most all wheel drive systems are designed for on road traction, being controlled by a slip-sensing center differential.  They are not designed for off road use.  A part time 4wd system like what is on a Tracker/Samurai typically has a transfer case with lower gearing available for rugged terrain and a locking center differential that when engaged applies power more directly to both the front and back wheels simultaneously.
Alan
When I grow up I want to be Stewie Griffin.
Offline 5282jt
  • 9
« Reply #3 on: December 28, 2005, 12:25:53 PM »
Thanks Shredder  and Snafu !! Perfect info!!  ;D
