Trackick poor heat? Must read!
  • 3335 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« on: December 28, 2005, 02:04:58 PM »
My sister was having poor heat in her tracker. We tried a thermostat but no help. Engine temp was as normal as one would expect for this time of year. The coolant looked really nice and I doubted that the heater core was plugged but it looked easy so I thought what the hell. I removed the heater core hoses. I then took a garden hose and flushed both ways threw the heater core several times. Then I reattatched the hoses topped off the coolant. I didnt think It did anything as I did not see any crap flow out of the core but it did. The heat works great and it only took about 5 minutes.
Mike
Re: Trackick poor heat? Must read!
« Reply #1 on: December 28, 2005, 03:59:37 PM »
I gotta try that! My Kicks heat sucks >:( Thanks for the tip, I have tried everything besides buying a new core.
« Reply #2 on: December 28, 2005, 05:33:14 PM »
I thought junk gets stuckin front of the core
and just keeps the hot air from getting out
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #3 on: December 28, 2005, 06:34:20 PM »
Is that why you moved to florida? Why dont you move to MN and I will fix your heater. Deal?
Mike
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: December 28, 2005, 07:11:57 PM »
Where is the heater core located in these that it only take 5 miniutes? I always thought cores were a pain in the bum to work on  ;)
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: December 28, 2005, 09:26:11 PM »
If you are just backflushing the core, all you have to do is disconnect the hoses.  That's easy.
...removing the core is hard...
Jim Z.
66 Apache camper
« Reply #6 on: December 29, 2005, 04:01:40 AM »
Mike
I think FL and no heat would be warmer tha MN with the best heat available :o I did look in your area when I was job hunting in the NW. Beleave me, there were many places with friends and wheeling I would of taken first (before South FL). Now that I'm here it's not to bad, except for not wheelin in a while :'(
Offline Cwkick
  • 888
« Reply #7 on: December 29, 2005, 06:33:36 AM »
You DO get to cruise around with the kicks top off most of the time!   :D
Cwkick
