Lifted the GV
  • 83 Replies
  • 17746 Views
Offline CE1_2NR
  • 21
  • 2001 GV 4x4
    • Accordingly Done
Lifted the GV
« on: March 18, 2006, 07:10:56 PM »
Took this past week off work to burn off the rest of my annual leave. JDMCRX and I installed the lift kit he designed and manufactured on my Suzuki Grand Vitara.
kit includes:
Here she is before surgery....
Me in mad scientist mode performing surgery...
I have a big tongue....my GF loves it !!
Here's some surgery pics....
We had to make some modifications in order to adjust camber like
slotting the top holes on the front strut mounts
and grinding some excess material off the spindle
Overall, it was a fun time. The front end was a bitch to do as my truck was uncooperative. A few hard to loosen bolts. Luckily his garage has a disgusting array of tools.
The finished product.
SHAZAM!!
I'd rather be a Dictator than a Dicktaster.....
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Lifted the GV
« Reply #1 on: March 18, 2006, 07:23:06 PM »
Nice DRYW soon some mud holes
01 GRAND VITARA
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: Lifted the GV
« Reply #2 on: March 18, 2006, 07:37:54 PM »
That is nice and very impressive. How much is this lift again?
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Lifted the GV
« Reply #3 on: March 18, 2006, 09:06:41 PM »
Why'd you have to grind on the knuckle? ???
Offline JDMCRX
  • 1110
Re: Lifted the GV
« Reply #4 on: March 19, 2006, 12:22:52 AM »
Cause when u lift ur truck ur control arms go like this / \ which gives u positive camber so u have to bring the spindle inwards towards the inside of the truck . Ill have the write up done tomorrow u will see why
Josh
01 GRAND VITARA
Offline JDMCRX
  • 1110
Re: Lifted the GV
« Reply #5 on: March 19, 2006, 12:27:05 AM »
The lift is $330 cdn or roughly $280-290us depending on the US dollar
Now we got a chance to measure how much the strut spacers give u drop wise.  Drop wise boths sides we gained 2 1/8".
As for the lift the rear gives u 2" rear and 1.75" front. Alignment was only out slightly camber Dead on  :P
01 GRAND VITARA
Offline bzzr2
  • 1011
Re: Lifted the GV
« Reply #6 on: March 22, 2006, 11:33:35 AM »
looks good, need to get some pics up of my tracker soon...  actually took some.  so, you think those 4dr's can keep up to my 2dr in the upcoming muck that our area's gonna be so full of real soon?!?!?!
when i installed my 1inch front spacer i didn't need to worry about that spindle issue at all just as an fyi for others.
also, for the rear shocks, i put in some rear crown vics, the ford replacement part from dealer.. the bottom shock mount doens't fit with the stock bolt and the aftermarket bolt will not fit either.  ended up going to home depot (canadian tire was like talking to f'in monkeys as usual..) and grabbing a little metal insert from the plumbing section to fit into the bushing, fit perfect with the bolt but is a little short and i'm figuring it will eventually work its way into the rubber and wreck the bushing.  what did you do about this little problem?  anyway the ride is much improved with these shocks..
09 taco reg cab short box 4x4
Offline JDMCRX
  • 1110
Re: Lifted the GV
« Reply #7 on: March 22, 2006, 04:27:27 PM »
RANCHO and some custom cut sleves :)
01 GRAND VITARA
Offline bzzr2
  • 1011
Re: Lifted the GV
« Reply #8 on: March 23, 2006, 12:11:30 PM »
cool, where did you pick up the sleeves, i couldn't find anything the right diameter that i could cut doing my last minute running around..   i should probably fix mine up properly.  another question, any spacer material kicking around?  i could potentially use more lift for the back end, the girly springs sag quickly with weight in them.  maybe a quarter to half an inch, lemme know.
B
Offline 2K1USGV
  • 218
Re: Lifted the GV
« Reply #9 on: March 23, 2006, 03:43:37 PM »
What did you use to extend the rear bump stop? It look like the rear sopacer swallows the stock one. And how is the new one in keeping the spring front jumping off the spacer? Also how is the brake line length with the suspension fully extended in the front?
« Last Edit: March 23, 2006, 03:59:28 PM by 2K1USGV »
Offline JDMCRX
  • 1110
Re: Lifted the GV
« Reply #10 on: March 23, 2006, 07:58:02 PM »
The rear spacers im gonna be making up some rear .5" spacers the bushing what size u need like ur shocks the inside diameter
josh
B
01 GRAND VITARA
Offline JDMCRX
  • 1110
Re: Lifted the GV
« Reply #11 on: March 23, 2006, 07:59:00 PM »
Tht on pic is not right we were playing around with shit.
01 GRAND VITARA
Offline bzzr2
  • 1011
Re: Lifted the GV
« Reply #12 on: March 27, 2006, 02:06:53 PM »
cool, get in touch when you're about to get those .5 spacers going
b
josh
Offline Chevzuki
  • 71
  • Grand Vitara disguised as a Chevy Tracker
Re: Lifted the GV
« Reply #13 on: March 27, 2006, 08:14:52 PM »
Looks good, now you can fit even bigger tires.  8)
2004 Chevy Tracker ZR2 4DR 4WD, 2.5 liter V-6, 4-SPD auto trans, P215/75/R15 Goodyear AT tires (for now), bone stock daily driver
Offline 2K1USGV
  • 218
Re: Lifted the GV
« Reply #14 on: March 28, 2006, 03:29:15 PM »
Some questions for you guys regarding the spacers in the front. When you installed the spacers, how tall were the spacers in the front? Did you do anything with the steering befor eyou bolted it back to the spindle? Did you have any problems with the sway bar connecting to the spindle after the spacer was installed?
