yellowish plastic headlight lens
  • 7 Replies
  • 2219 Views
Offline eyb
  • 84
  • I love YaBB 1G - SP1!
« on: September 09, 2009, 04:17:06 AM »
How does one get rid of the yellowish color build-up of the plastic headlight lens of a GV? I think the situation was further aggravated by a pair 100 watt bulb used by the previous owner.
Are there available wax, chemicals, etc. that can be used to restore the lens to its original condition?
Re: yellowish plastic headlight lens
« Reply #1 on: September 09, 2009, 06:43:41 AM »
There are various polishing kits out there - Meguiars Plastx is what's available in my neck of the woods, and it seems to do a decent job.
Search and you'll find all sorts of recommendations - depending on how bad it is, start with fine sandpaper and work your way up to the polishing compounds.
Offline trackinstile
  • 435
  • Too young to quit........Too old to change........
« Reply #2 on: September 10, 2009, 06:16:22 AM »
We have an Advanced Auto Parts by my house and they sell a kit, with sand papaper and polishes, I've seen other people use it with good results
A wise man once said, "Wherever you go...........There you are.............." 2000 Tracker 4 door with the 2.0 liter "Big Block". 5 speed 4WD  2001 XL-7 EX II
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #3 on: September 10, 2009, 03:31:00 PM »
I used one of those kits ($20-$30 I think).  The results were rather impressive.....for 4-6 months.  Then, it was right back to that same old yellow cloudy look.  Unfortunately, it only seems to delay the inevitable.  Sorry.....I would recommend new lamp housings....maybe from ebay or another discount source.  Good luck!
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline eyb
  • 84
« Reply #4 on: September 10, 2009, 08:58:05 PM »
thanks guys! I really don't mind rubbing and sanding my plastic lens eery 4 months or so. Brand new headlights are a bomb to purchase, especially the OEs.
Offline blacknight
  • 987
    • Gonzookin
« Reply #5 on: September 11, 2009, 07:37:36 AM »
did mine with meguiars and 2000 grit sandpaper look like new.  Now I just tuch them up with the meguiars and they are good to go.
George
Offline eyb
  • 84
« Reply #6 on: September 16, 2009, 08:25:38 PM »
Thanks for all the inputs.
I tried going over the various headlight restoration kits available in the market. In summary, there are 2 kinds. One is applied using an electric drill, while the other one is applied manually, by hnad.
Has anybody know the advantages/disadvantages of these two?
« Reply #7 on: September 17, 2009, 08:08:34 AM »
Well - if you do it by hand, it'll require a lot more elbow grease  ;)
