Steering issue, any ideas
  • 1635 Views
Offline toofaroffroad
  • 226
« on: September 22, 2008, 10:58:05 AM »
I'm getting a serious shuddering in my steering wheel from around 40 mhr to 55mhr. I have recently had the tires checked and balance and also had an alignment done. Any ideas what this could be?
Offline 1badzuk2
  • 89
    • my sammy more pics check it out
Re: Steering issue, any ideas
« Reply #1 on: September 22, 2008, 03:02:21 PM »
mine did the same thing i had to have another aligment and that fixed it up  or you might have bent a bar...
built sammy locked front an rear full roll cage 6 5 1 tc gears 96 16v motor and alot alot of mods
« Reply #2 on: September 23, 2008, 12:40:04 PM »
Didi u check the bearings?
Offline Armour
  • 360
« Reply #3 on: September 23, 2008, 09:03:13 PM »
Front struts could be worn out!?!?!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: September 25, 2008, 09:50:21 AM »
did this start after haveing  the tires checked and balance and alignment.  Did they rebalance the tires?  Did you try swapping the the fronts for the rear? Check for missing wheel weight, the ball joints, tie rod, wheel bearings, and struts.
George
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #5 on: September 26, 2008, 06:36:12 AM »
Almost killed my brother with loose lug nuts once.
XL-7 front coils
1.5" rear coil spacers
  • 226
« Reply #6 on: September 29, 2008, 09:45:18 PM »
It was inner tie-rod ends. They were warn out on the ball joint. Made it shudder on the highway, thanks
