Neon seats mounted!
  • 22 Replies
  • 4421 Views
Offline Bama Bill
  • 6
Re: Neon seats mounted!
« Reply #15 on: March 29, 2012, 08:42:02 PM »
It'll seem like a different vehicle.I lke the fact they sit a little higher.
Bill
91 Samurai 2wd
Montgomery,Al
Offline Godzuki84
« Reply #16 on: March 30, 2012, 07:59:41 AM »
^I mustve drove around for a little under an hr yesterday lol, the seats are just so nice! Now I just need to get the pass side to fold down like the samurai seat!
The little zuki that could
Offline Capt
  • 738
  • 28
« Reply #17 on: March 30, 2012, 03:40:07 PM »
If you mean forward?.........
Oh, So Sad, you are in the boat that I'm in.
4 door Neon seat can not fold forward, the seat "Ratchet" isn't set up to do that !!
When I got mine, the "Pick Apart" said $50.00/set & we'll get them out, Charcol Good?
It sounded GREAT, only to find out they were 4 door seats and I was already Wacking & Hacking B4 I found out.
CAPT
Offline Godzuki84
« Reply #18 on: March 30, 2012, 05:05:05 PM »
^I heard that you can switch the 4dr mechanism to a 2dr one and vice versa, the seats are all the same just the mechanism between body styles, I will probably go to the j/y this wkend and  try to find a 4dr seat and a 2dr seat and see if I can switch them.
« Reply #19 on: March 30, 2012, 07:59:27 PM »
Look at the hinge mechanism and see why it is not folding forward.  You can modify it to fold forward.  Seems like you have to remove one of the bolts, remove (maybe drill out) a spacer and put a shortened bolt in, or put it in from the opposite side or something.  I did it to one of my neon seats...but its been long enough ago, I don't remember the exact procedure....and that samurai isn't here, so I can't go look.
Offline Bama Bill
  • 6
« Reply #20 on: March 30, 2012, 11:19:55 PM »
I put the two door mechanisms on the right seat and left the drives as is.I got it off a trashed seat at the pull a part.
Bill
91 Samurai 2wd
Montgomery,Al
Offline Godzuki84
« Reply #21 on: March 31, 2012, 08:35:03 AM »
^Was it pretty easy to switch them out? I too am gonna leave the drivers side as is since people don't usually climb in on the drivers side anyways.
Offline Bama Bill
  • 6
« Reply #22 on: March 31, 2012, 03:46:22 PM »
It was simple.You have to pull the plastic cover off with a torx driver then there are three,I think it was, on the seat bracket and pull the seat cover up on the seat backs where there are two more.The outside ones are the ones you replace.The insde ones fold forward anyway. Slide the seat all the way forward and go to work.
Bill
91 Samurai 2wd
Montgomery,Al
