Install- Altered Ego 4.5" lift kit
  • 88 Replies
  • 23038 Views
Offline talonxracer
  • 1284
Re: Install- Altered Ego 4.5" lift kit
« Reply #75 on: November 08, 2011, 07:31:38 AM »
I finally found the measurements that I took of the Sidekick before the lift, she was sitting at approx 27" to the lip of the front wheel well arch on the stock limp spagetti coils, she is sitting at 36" right now. That is a 9" lift out of the altered Ego lift kit and the 31x10.5x15's.
« Reply #76 on: November 11, 2011, 12:12:55 PM »
Looks better now.  :)
Offline talonxracer
  • 1284
« Reply #77 on: November 19, 2011, 04:53:03 PM »
Took a pic today and thought I would share it. Plenty of ground clearance, my only concern is the front diff, gotta get a skid plate under there!
Offline great08
  • 10
« Reply #78 on: November 20, 2011, 01:31:00 AM »
Nice writeup.
Thanks for sharing!
Marty
Offline talonxracer
  • 1284
« Reply #79 on: November 20, 2011, 02:21:37 PM »
Thnx!
My uncle is a heep guy, he bet me a buck that the zuki couldnt climb up on some logs, he said if his  jeep couldnt the zuki couldnt, especially with open diffs, LOL she climbed right up on there with very little sweat and fanfare, LOL I am a buck richer now!
« Reply #80 on: November 21, 2011, 03:42:09 PM »
Definitely get yourself some skid plates! And while your at it strap down that front diff to prevent breakage. Been working on mine for years and many miles now. Nice flexy IFS, that Altered Ego stuff is THE WAY TO GO!
Offline talonxracer
  • 1284
« Reply #81 on: November 21, 2011, 04:35:11 PM »
yeah I wasnt sure what I was going to do with the front diff, but I was thinking of going with steel parts if and when I put a locker or ARB in. I found a spare transfer case and will do 4.24 gears and install the twin sticks I have.
I wanted to go with the Altered Ego skid plates but that 10% duty to get it into the States sucks big raw green donkey dugans!
« Reply #82 on: November 22, 2011, 06:55:34 AM »
I was running their diff drop brackets and the aluminum third only lasted one trip, it met a rock and shaved off the bottom of the differential. I am pretty sure it was worse than it would have been, as it was sticking down that much further.
I picked up a front OEM skid plate and paired it with the alteredego transfer skid & transmission skid. I'm happy so far.
« Reply #83 on: November 22, 2011, 09:40:26 AM »
I've been running an ARB in the stock front diff aluminum housing with my own diff strapping system and Calmini skid plates with no damage whatsoever in 50K miles and some pretty seriously wheeling. The aluminum one will hold up fine if braced from twisting and is a bunch lighter than the steel counterparts.
Offline talonxracer
  • 1284
« Reply #84 on: November 22, 2011, 12:36:00 PM »
yep that is the same skidplate I was planning on, it sucks when UPS holds your package ransom for customs and duties, so the altered ego skid plates are out, and besides i havntt been able to get hold of them, no phone or email replies.......
I will check out your strapping a little later, I was trying to change the rear D-shafts ujoints and procedded to hammer off the tip of my finger!
« Last Edit: November 22, 2011, 12:39:17 PM by talonxracer »
Offline great08
  • 10
« Reply #85 on: November 23, 2011, 06:52:44 PM »
Ouch! Been there before. The tip just popped right off and sprayed a few inches away. Can't even tell now though. Been about a decade and I don't even remember which finger it was. I used a bandaid to hold the tip on until it stuck back to the finger. Was just skin though.
« Reply #86 on: November 25, 2011, 10:40:09 AM »
This is what I made for front Skid Plate.  A fab shop would bend it up pretty quickly.  I made a cardboard MOC of how I wanted it bent, and use an angle finder to get it close.  My dish on the bottom (used propane cylinder) is not heavy enough.  Mine is 3/16" and can be bent (but not by much).  I welded stiffeners on the sides to keep it from bending.
Get a piece of cardboard and see what you come up with.  (If you want my angles and dimensions I can get them next trip under it.)
Offline arced
  • 55
RE: Install- Altered Ego 4.5" lift kit
« Reply #87 on: March 16, 2016, 05:15:31 AM »
DELETED
« Last Edit: April 05, 2016, 11:20:25 PM by arced »
Offline arced
  • 55
