trouble shooting engine misfire, 96 x-90
  • 8 Replies
  • 3058 Views
Offline sumozuki
  • 22
« on: December 20, 2011, 10:31:12 PM »
1.6 16 v 96 x-90 auto, engine runs fine until I put the auto transmission in drive then it develops a misfire.
Offline talonxracer
  • 1284
Re: trouble shooting engine misfire, 96 x-90
« Reply #1 on: December 21, 2011, 06:48:47 AM »
Have you changed plugs and wires? Any CEL codes? EGR system may need to be checked,cleaned.
Offline sumozuki
  • 22
« Reply #2 on: December 23, 2011, 11:06:56 AM »
Thanks talon, i pulled up a iat code & fixed that, plugs, cap & wires were done also,will chk the egr now, i hope thats it,i'll let ya know! ??? ???
« Reply #3 on: December 24, 2011, 12:58:36 AM »
I would also check the 02 sensor.  Sometimes a bad 02 can cause some weirdness.
Offline talonxracer
  • 1284
« Reply #4 on: December 24, 2011, 08:56:36 AM »
Also a cracked exhaust mani(usually between #3 and #4) can cause a over rich condition resulting in misfires.
Offline sumozuki
  • 22
« Reply #5 on: December 30, 2011, 07:05:47 PM »
swap egr, no change
Offline KJMac
  • 280
« Reply #6 on: December 31, 2011, 01:20:30 AM »
swap egr, no change
Did you swap out the module...diaphram? That was the problem with mine!
« Last Edit: December 31, 2011, 01:42:45 AM by KJMac »
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
« Reply #7 on: December 31, 2011, 08:54:07 AM »
Misfire as in firing at wrong time, or not firing when required?  If is not firing properly when shifting into drive, leave in drive and pull plug wires one at a time to find bad cylinder.  Move injectors and retest to see if problem moved.
Offline sumozuki
  • 22
« Reply #8 on: January 03, 2012, 07:57:10 PM »
Got er goin, THANK YOU EVERYONE 4Ur Input, KJMac you were right in the $$, Diaphram did fix it!
