Longer traveling rear shocks
  • 22 Replies
  • 5529 Views
Offline jagular7
  • 1026
  • Jagular7
« on: December 04, 2004, 04:12:10 PM »
I've added a 2" Jeep spacer to the top of the springs, added a Jeep lower bump stop riser on the axle mount to compensate for the spring spacer, and now just added a set of stock XJ front shocks. They provided an extra 1" droop at the wheelwell.
My -7 has 225/75-16's, measuring from ground through axle center to wheelwell, I measured 36".
Lenexa, KS
Offline blacknight
  • 987
    • Gonzookin
Re: Longer traveling rear shocks
« Reply #1 on: December 05, 2004, 01:07:46 AM »
odd,  I have calmini's 2.5 lift w/ 245/75/16 and I only got 33 1/2 in ???  Wounder if my springs are starting to sag???
George
« Last Edit: December 07, 2004, 04:31:43 AM by blacknight »
Offline blacknight
  • 987
    • Gonzookin
« Reply #2 on: December 05, 2004, 01:09:28 AM »
You didn't take any numbers befor you did your lift?
George
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: December 05, 2004, 11:35:07 AM »
Read over my message, and see that I mislead. It's not that tall staticly. That's the height when the rear tire comes off the ground lifting with a floor jack at the frame. Sorry. Static height is 34" (just measured). Still higher than yours???? I'm using the 2" Jeep (XJ/TJ/ZJ)poly lift blocks.
Just mentioning that the stock XJ shocks (came from a 91 that went to a 4" lift) will give better droop for even a stock XL7.
Lenexa, KS
Offline nomaad
  • 179
  • I wanna go!!
« Reply #4 on: December 06, 2004, 03:47:57 AM »
Jag, Just took a look at your suspension photos. Have you tried any of those other springs in your rig? And also did you happen to calculate spring rates of the stock springs when you had them out?
Offline jagular7
  • 1026
  • Jagular7
« Reply #5 on: December 06, 2004, 06:02:06 AM »
Those other springs being the ZJ's are a friends. I've got the blocks in the rear and that is rather too easy to perform. Next is to get some springs or blocks for the front to lift 1.5-2". Since the lower control arm's throw is short relative to the spring, I can't get anything in there. The taller springs wouldn't work.
I however have came up with an idea to install the block. By making a rigid spring compressor, I'll let the springs compress into this while lowering the a-arm. The static and expanded heights of the spring is what makes it difficult. I've purchased several compressors from Harbor Freight. I'll be cutting the long all-thread to size.
But first, I need to drop the upper strut mount. I've got the flat plate cut and just need to trim for size now. Currently, work, being a Dad, life is getting in the way. Plus, there is an event local to KC this weekend at KanRocks.
Lenexa, KS
Offline blacknight
  • 987
    • Gonzookin
« Reply #6 on: December 07, 2004, 04:30:44 AM »
OK went out got some new numbers:
with the rear jacked up:
40" from ground to wheelwell
16" from top of rim to wheelwell (takes tires size out of hieght)
rear sitting on the ground:
33 3/4" ground to wheelwell
10 1/2" top rim to wheelwell
Still I think that I may be getting spring sag :(
george
Offline joejoekuo
  • 41
  • 2004 XL_7
« Reply #7 on: December 09, 2004, 05:01:44 PM »
This spring we call" Bowl Spring". The traveling is 63cm(For skyjacker 63cm absorber)
Offline nomaad
  • 179
  • I wanna go!!
« Reply #8 on: December 18, 2004, 12:50:09 AM »
What are you guys doing with the brake line that comes over the frame to the drum when you are extending the shocks in the rear? I know when I disconnect the track bar it droops about another 2" then the brake lines are stressed all the way out as well. I have the braided line from the control to the housing but those side runners would have to be addressed, right?
also, I saw a GV yesterday online that had the Calmini shocks in the rear but he had fabbed up a 2" bracket for the bottom mount which gave him an extra 2 of droop. Any thoughts? I wonder if a shackle style something or other could be made that would give the added droop and compression? It would close and open just like a shackle. But then again, why not just order new shocks . . . pretty neat though. ;D
Offline idaholwb
  • 772
« Reply #9 on: December 26, 2004, 04:24:17 PM »
I'm not quite sure if I'm seeing things right, but does that little GV have a Dana 44 rear axle??
97 Sport
265/70-16s
2" lift
2.0 swap
Offline joejoekuo
  • 41
  • 2004 XL_7
« Reply #10 on: December 27, 2004, 12:46:03 AM »
I am not quite sure,too.But we could change the rear axle to Dana 44(Only for GV, not L-7). See this: http://www.offroad.org.tw/dousun/gv/index.htm
and link to NO3.
« Last Edit: December 27, 2004, 12:46:53 AM by joejoekuo »
Offline blacknight
  • 987
    • Gonzookin
« Reply #11 on: December 27, 2004, 06:13:51 AM »
I tryed the link but I think their site is down or the link is bad  :-/ Why not the XL-7 the axles are almost the same as the GV???
George
Offline joejoekuo
  • 41
  • 2004 XL_7
« Reply #12 on: December 29, 2004, 10:52:13 AM »
George
The link is good,isn't it?
The drivers of XL-7 in Taiwan have the same question about the rear axle. They looks like only L-7 is longer. But GV has a lot of kit to modify, not for L-7.
Offline blacknight
  • 987
    • Gonzookin
« Reply #13 on: December 30, 2004, 11:04:10 PM »
Never mind got it to work. Had to look at it from home :P
George
Offline blacknight
  • 987
    • Gonzookin
« Reply #14 on: December 31, 2004, 01:56:51 AM »
This was translated and copied fromhttp://www.offroad.org.tw/dousun/gv/%E5%A4%A7%E7%9B%A4%E8%88%87%E9%98%B2%E6%BB%91.htm
3. 大盤 and skid resistant reequipment:
But after raises trades the big tire. Already and the original factory was different besides the ratemeter speed The power drains also may feel But only may the method which changes the power Is changes 大盤...
First Latter 大盤
The GV original factory final gear ratio is 4.875:1 but attempts is US standard DANA5.857:1 大盤.. Moreover Between the work place also has a system 大盤 to be possible to supply the choice. But Material quality and abrasive resistance. Or chirp 音值. It is said has bad somewhat... But trades 大盤 goal Is because Che Yu reequipped the big embryo. Causes the tooth to compare and the tire is unable to match Front therefore can decrease the torsion output.. But generally replaces 大盤 usually also can choose LOW some. Sacrifices some extremely 速來 front section use.. Also relatively conforms to cross country now and then the urban district driving low speed torsion demand
US standard 60% truetrac skid prevention differential device
The beautiful gauge GV hind axle may directly replace the US standard TRUETRAC 44 skid prevention differential devices It transmits using the helical gear the torsion to the wheel But induces between the wheel the resistance difference or the wheel rotation speed difference fixing device.. Goes when the common path the wheel axle to car dealership 轉彎處 cannot the pressurize, and the comparatively not different sound produces Lower failure rate Belongs to the higher-level 螺旋齒 wheeled fixed fitting... but the skid prevention to be allowed to provide stabler and the entire time interval skid resistant function Regarding high speed anabatic wind sand The rainy day excessively is curved The monowheel is hanging.. And so on No matter is the cross country road surface or the common path all has very in a big way is of help For example: BMW.Volkswagen. Outside racing bicycle High-level after the nearly SUV vehicle all has the equipment the skid resistant differential device to provide the most immediate help.. But the newest skid prevention is the machinery screw type 磨片 -like the abrasive resistance and the sensitivity are all better than
Has installed good 大盤 and the skid resistant hind axle
When trades the big tire Drains the power in as soon as steps on the oil instantaneous... Then felt Therefore The second step reequipment is increases the power primarily But faces the question is. Dismantles the axle center at the same time. Whether or not considered adds on the skid resistant differential device to reduce the reassembly the wages
After original factory in differential device
After this is the original factory the differential device interior Attempts DANA with on 大盤 to compare May see original factory 大盤 weak somewhat...
